Dark spot on TV screen
  • bridd2263
    • Sep 2012
    I have a Vizio Vx37L HDTV10A about 2 years old and the screen shows a dark area on the upper center of the screen when the video is showing a light or bright color sceam. I was able to check all the caps, power supplies and seems that the TV is in good working order . Does this sound like it could be a T-con board problem or something else I have not looked into.
    Re: Dark spot on TV screen
    It is most likely the LCD panel itself, especially if it is a panel made by CHUNGWHA or CHI-MEI. It is known as "mura".
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Probably impossible to guess without being able to see it - have you always owned the set and its got worse.
      Could be someone (kids) have whacked it, could be a bulb going out, You could read up on Mura a flat screen panel defect.
      • Rozp
        70LE660U dark cloud or black screen with sound.
        by Rozp
        Hello Everyone,
        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
        08-29-2023, 05:25 PM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
