Samsung 32" ln32b360c5d
    Re: Samsung 32" ln32b360c5d
    Can you post a picture of the bottom of the board? You can determine which windings go where by looking at the schematic, usually.
    • Peale
      • Apr 2009
      • 96
      All of the photos of the boards are here:
      https://www.badcaps.net/forum/showpo...37&postcount=2
        OK, it is very rare for a transformer to fail, but here is how I expect the windings to appear shorted.
        • Peale
          • Apr 2009
          • 96
          Either I'm doing it wrong, or it's very, very shorted. Every one of those points appears shorted. But, wouldn't that not allow the TV to operate, at all?
          I'd been talking about the inverter transformers, above. Those I finally figured out, and they read: 1.073, 1.076, 1.043, .993
            Nope, it should be shorted.
            An inductor (which is basically what a transformer tap is), should always appear shorted.
            You need a ring tester to verify the transformer turns are not shorted. However, this is very rare with SMPS transformers.
            • Peale
              • Apr 2009
              • 96
              #26
              I understand now, I think. You were looking to see if any of them were open?
              Okay, on to the next thing - now what?
                I missed most of this thread. Tell me, are 5.3V and 13V are stable on the PSU outputs?
                If the Power ON/OFF line is changing, then this could be the main board shutting down the PFC, causing the problem.
                http://www.tgohome.com/ServiceManual...g_BN44-00289A_[SCH].pdf
                The +13V powers the inverter, so it must be stable.
                • Peale
                  • Apr 2009
                  • 96
                  #28
                  If I've metered correctly, 5.3V is stable, as is 13V. The DET_5V goes from 4.74V to nearly zero when it starts flashing on and off.
                  • Peale
                    • Apr 2009
                    • 96
                    #29
                    Though 5.3 is reading closer to 5.24.
                      OK, near each inverter transformer there should be some ceramic caps (coupling capacitors), C1803, CI808, CI817, CI825 which should all read open on 2000 ohms.
                      • Peale
                        • Apr 2009
                        • 96
                        #31
                        Yes, this is accurate. All reading open. If I put the meter on 2M I get a reading, but not until then.
                          So if DET_5V is dropping out, check if the output of the LM358, UI802, pin #1, is high. If so, it might indicate that the driver detect circuit is detecting a stuck output.
                          • Peale
                            • Apr 2009
                            • 96
                            #33
                            If I've done it correctly (black lead to ground, red lead to pin 1) then I'm getting nearly nothing. There was a sudden spike up to ~3.2V, but then that was gone, too.
                              Problem is, I do not know if DET_5V should be high or low. The only way to be sure would be to disable the error detection -- force it at 5V or 0V -- and see what happens. Do you want to try that?
                              • Peale
                                • Apr 2009
                                • 96
                                #35
                                I'm assuming a possible risk would be blowing the board?
                                Run a jumper from the harness to that pin?
                                When it's at zero, which is where it starts, wouldn't that be...well...zero?
                                  I don't think there's a risk of blowing up anything on the board. The trouble is that you'll have to cut one of the wires on the harness going to the main board, which could be tricky.
                                  • Peale
                                    • Apr 2009
                                    • 96
                                    #37
                                    It would be easier to slice the trace, instead. Easier to repair, also.
                                      You could do that. Then use a 100~470 ohm resistor to pull it to 5.3V, see if the set turns on, if not, try GND, through 100~470 ohms.
                                      • Peale
                                        • Apr 2009
                                        • 96
                                        #39
                                        Okay, so...which trace should I cut, exactly?
                                        At what points should I be connecting the resistor?
                                          Cut the trace leading to the DET5V pin.
                                          Then connect DET5V (on the main board end) to 5V or GND using the resistor.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
