Hitachi 55VG825 blowing bulbs
  • uberplasma
    • Oct 2011
    • 85
    Hi everyone
    Got this 55" projector for free, said bulb needs replaced, so replaced the bulb and it worked for a few minutes then blew the bulb, so i pulled the back cover off and saw this component(in pic, circled) glowing every few seconds, and squaking while it cycled on. Couldn't find the schematics for the lamp ballast anywhere, and haven't pulled the power board out yet.
    Any ideas on why this glowed, or any help on direction without schematic would be great.
    Cheers
  • selldoor
    Slow Learner
    • 7870
    Re: Hitachi 55VG825 blowing bulbs
    It is a gas discharge tube infor here:
    https://cdn.badcaps-static.com/pdfs/...21ee8da115.pdf
    • uberplasma
      • Oct 2011
      • 85
      Thx
      so this should glow if the bulb is burnt?
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • ezenia
        LUMIMAN Smart Bulb IC ID?
        by ezenia
        I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
        In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
        04-28-2025, 05:56 PM
      • wolf1976
        hitachi 50hk5600 problem with display
        by wolf1976
        hi
        i have the above tv and the display starts distorts the display at only in applications like you tube
        after and on the didital channels
        now without connect the antenna only the image of itsselfs tv i have the image i have in attach
        i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
        can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
        09-13-2025, 02:26 PM
      • GraphicMan
        Niky 1000 UPS making strange sparking noises (video)
        by GraphicMan
        anyone can explain what and why is this sound "ezz ez ez zzz" clearly starting from 0:34, the ups is niky 1000, i am using 7s6p good lithium 18650 cells pack, that sound only appear when i load any pc or lcd or crt, but never ever when using even much higher load 200w tungsten bulbs, althogh the sound, it never shut down nor give a warning and the pc or lcd or crt works completely normal at all times, in the video u can notice that the bx100 (voltmeter) is restarting with the sound, also the bulb flickers with the sound, i have checked only the largest cap on board (which is not that...
        02-27-2024, 08:09 PM
