sharp lc-46d62u
  • t.j.
    • Apr 2010
    • 383
    • canada
    sharp lc-46d62u
    have not cracked it yet! but heres pic of what it doin! seem to remember if lines like this it screen an not fixable!
  • drpj23
    • May 2012
    • 528
    Re: sharp lc-46d62u
    It could also very well be a main board problem considering the lines seem to appear behind the OSD.
    • t.j.
      • Apr 2010
      • 383
      • canada
      Re: sharp lc-46d62u
      the main board has 2 red led on it one comes on an stays solid an the other just blinks, re seated all the wiring an turned on, lines where gone! except when in menu's or any osd! only lasted a minute before lines came back, but this time red an blue! an worse them before! will post pics soon!
      • t.j.
        • Apr 2010
        • 383
        • canada
        Re: sharp lc-46d62u
        when tv first fires up it looks good for about 2 seconds. then does the lines thingy! will have internal pics shortly!
        • drpj23
          • May 2012
          • 528
          Re: sharp lc-46d62u
          Hmm, got any freeze/dust spray?
          • t.j.
            • Apr 2010
            • 383
            • canada
            Re: sharp lc-46d62u
            nope, will get some after holidays, could always put it out side for an hour! lol..
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Re: sharp lc-46d62u
              Checked for bad caps?
              Since it works for a few seconds, it seems that a bad cap could be causing a voltage regulator to go wonky. What do you think?
              Muh-soggy-knee
              • t.j.
                • Apr 2010
                • 383
                • canada
                Re: sharp lc-46d62u
                the main board is all pollies! an i hit it with heat an no change! will do further testen on it after holidays, thanx!
                • zoontz
                  SHARP LC-70UD27U black and white lines
                  by zoontz
                  Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                  What I have tried so far.
                  I have tested all HDMI inputs with the same results.
                  I have checked for firmware updates.
                  I have reset to factory settings.
                  I have removed...
                  07-09-2024, 05:50 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • jaco2d
                  Sharp 50bj2ke horizontal lines
                  by jaco2d
                  This is only my seond post and so far i am very impressed with the forums.
                  I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                  The small white box thing in the pics is not the tv its a reflection from the window
                  Any suggestions...
                  11-01-2022, 04:45 PM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • DrvLikHell
                  Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                  by DrvLikHell
                  Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                  The...
                  02-05-2025, 01:44 AM
