55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
  • tw2005
    replied
    Re: 55 inch Plasma Viera (VIERA TC-P55GT30) not turning on. 7 blinking red lights.
    Originally posted by awalt
    Please give me some advise. I have trouble shot my tc-pc55gt30 according to the manual and my fault (seven blinks) leads me to a tnp80915 a board replacement. Is there any further troubleshooting to do before I purchase a replacement board?
    Thanks1
    That would be unusual for A board for 7 blink.
    describe how you reached that conclusion
  • awalt
    replied
    Thanks1
  • tw2005
    replied
    Originally posted by Havasu
    I am sending the SC board to ModusLink, it will be a repair and return as they don't have the boards in stock. When I get the SC board back, shouldn't I be able to connect the ribbon, and power connector. Leave the SD/SU disconnected, and not grounded and jump SC50 again? If the 7 blinks do not happen, then the assumption is it was the SC correct?
    Is there anyway type of troubleshooting I can perform to isolate if the issue is with the SD/SU board?
    If I connect the SC board to the SD/SU board, and I still receive the 7 blinks, assuming the SC board was repaired and functional, is the assumption at that point that it was the SD/SU board, and that the SC board has absolutely been blown by shorted SD/SU boards?
    The only way to know if the SC board has been blown at that point in my mind is to test the SC board when I receive it back. Connect power and the ribbon, leave disconnected from SD/SU, jump SC50, and I assume I won't have the 7 blinking lights, because the SC board is now repaired.
    Then connect the SD/SU boards. Power up the TV. IF I still don't have a picture, then the assumption is the SD, or SU board needs to be repaired. At that point to test to see if the SC board has been damaged I would disconnect the SD/SU board again, and remove ground. Retest the SC board by jumping SC50. If I now receive the 7 blinking light, then the SC board has an issue again to, and all boards have to be repaired. If the I still have no blinking power light, then the assumption would be the SC board has been repaired and is still ok, and the issue is in the SD or SU board. Am I missing anything?
    I really appreciate all the advice, and info.
    Sometimes the Buffer boards blow the SC board , so when you have a bad SC, you should also check the buffers. we know the Sc is most likely bad. If you get it repaired and then install it with the buffers then itmay pop again. My advice is see if modus will check them for you. I don't think those buffers are repairable or who does them. Normally just get replacements.
  • Havasu
    replied
    Originally posted by tw2005
    At a minimum SC board but you need to somehow check the sd/su boards for shorts or roll the dice and replace the SC only without checking. Worst case scenario is the sd/su are shorted and blow the Sc. Best case the TV is fixed.
    Whoever fixes the Sc board for you may be able to test the buffers for a fee or free? If you are just buying a new board then somehow you're going have to work out how you want to achieve this.
  • tw2005
    replied
    I didn't have a jumper, or alligator clips small enough, so I used some speaker wire, split the two sides, and stuck them in the socket for SC50 over the two pins. The buffer connectors between the SC, and SD/SU board were disconnected, and so were the ground screws for the SD/SU board. The SC board was completely screwed down. The light still blinks 7 times, so that is the SC board correct?
  • Havasu
    replied
  • Havasu
    replied
    Not sure if a computer jumper will fit but a small alligator clip I find can sit across those and work. If the TV turns on with no blinks then it's just the buffer boards. If it still 7 blinks then SC board and the buffers still should be checked for shorts.
    it's the 4 bigger bolts that have metal pads under them for grounding that get removed.
    Ok So disconnect SU/SD boards from SC board.
    Take out 4 bigger screws on SU/SD boards
    Alligator clip, or something that will go across the two Pins of sc50
    If no Blinks it's the SU/Sd boards. If it still blinks then it's the SC board.
    I'll be doing this today. Thanks.
  • tw2005
    replied
    I had all 3 unscrewed. So I need to have the Sc board completely screwed down?
    As far as the SU/SD are the bolts that ground those boards the bigger of the srews? I believe there are 4 bigger one's that go along the front, and then 3 smaller one's that are at each end, and in the middle.
    Where can I get a 2 pin jumper? Or can I just hold a piece of wire across the two to short them together? What outcome's are possible and what do they tell me?
  • Havasu
    replied
    So once the Sd/su are disconnected, the 4 bolts that ground them are removed, then SC50, 2 pins are shorted together, then the TV is turned on. Is that what you did next? You do this with the SC bolted in correctly so it's grounded to the chassis. i.e. do not remove it. leave insitu.
  • tw2005
    replied
    Ok disregard my last message. I lifted up on the SC board and then realized that the connector with the tabs came out, not the pins separated. That was my first thought earlier, that's what it seemed like, but I got no movement out of the connectors.
    Here is where I am at. I disconnected the SU, and SD board from the SC board. I still received the 7 blinks. Then I disconnected SC20, and Sc2 (the ribbon and power connector from the SC board), and now I'm receiving 8 blinks instead of 7. Does this truly indicate the SC board as the culprit? OR, since the blinks change to 8 after disconnecting the SC board does that point to the Sc board being good, and aproblem with SU, and SD board?]
    I'm just trying to see if I can definitely be able to tell which board.
  • Havasu
    replied
  • Havasu
    replied
    I'm just not getting it yet. In what direction do these fingers come out? Do they go straight back? Does the SU/SD board go up while SC board stay in place?
    I am depressing the tabs, and pulling back from the SC board side? What am I missing. It really looks like those metal fingers go all the way through from The sc board through the connectors all the way back to almost the tabs, and I just don't see how they come out.
  • Havasu
    replied
    Great. Thanks. I really appreciate it. I may have some more questions along the way here. I just want to see if I can narrow down which board it is. I'm following a flow chart posted much earlier in this thread.
  • tw2005
    replied
    The connectors that have small flexible metal fingers on one side that are into a connector with the spring tabs you were talking about. I pushed in the tabs, and started to pull, but they felt like they were hung up. I didn't want to damage them, so you're saying press the tabs and pull firmly? It just seemed with the other two still connected I might damage the others pulling back too far.
  • Havasu
    replied
    the only connectors removed are the 3 from the SC to the SD/Su boards. So what are the easy ones you refer to?
    Squeeze the side tabs in , then gently wiggle side to side until it comes free. they are a tight fit.
    The 4 ground screws on the SD/SU boards are also removed, then the 2 pin SC50 connector on the Sc is jumpered , then the TV is turned on
  • tw2005
    replied
    Also, I can't find the Panasonic parts store that people have referred to. I have searched for it, and just can't find it. I have been having trouble just finding the SC and SU/SD board parts. I really just want to order them all and return what I don't use, to speed up the process.
    Shopjimmy, Payless Components are 2 I know or if it's just a bad SC board ModuslinkPTS do repairs if the board is hard to find.
  • tw2005
    replied
    In the first step I'm supposed to disconnect the SU/SD board from the SC board, leave the SC board connected and see what happens with the lights. All connectors are easy to disconnect except for the connectors between the SU/SD board and the SC board. I believe these are referred to as buffers. They are delicate/flexible metal pins that seat into a connector. The connector has spring loaded tabs on the SU/SD board side. I can't for the life of me figure out how these disconnect. Any help would be appreciated.
  • Havasu
    replied
  • Havasu
    replied
    I'm having a moment where I feel really dumb. I have a TC-P55GT30 and yes I have the 7 blinking lights of death. I've researching and reading this thread. I'm in the middle of trying to follow a flow chart that was posted on how to tell if the issue is the SC board are the SU/SD board.
  • hoggwild89
    replied
    They are easier to seat with the board NOT screwed in.
    Originally posted by hoptown101
    I have a picture again so the boards are fixed and we're making progress. Are there any tricks to getting the ribbon cables seated properly and how tough are those things? I feel like I'm going to tear them up tugging on them. I've tried reseating a couple of them 3 or 4 times with no luck.
  • bialag
    Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
    by bialag
    I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
    Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
    03-25-2025, 05:56 PM
  • Audeze
    Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
    by Audeze
    I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
    Does...
    10-06-2024, 08:54 PM
  • badcappo
    Dead Panasonic Viera TX-P65STW50 Plasma TV
    by badcappo
    Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
    Diode type G972s6 - D101 with a short
    Mosfet 06N90E - Q301 shorted
    Fuse T5AH 250V - F103 blown
    Diode D301 shorted
    Relay DG1U-17VDC II - RL001 blown
    I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
    11-24-2024, 11:27 AM
  • domix
    43pus6401/12 - no picture, blinking ambi lights
    by domix
    Hello i have 43pus6401/12.
    After turn on red light slowly blinking and ambilight blinking randomly, different colors fadein/out, etc
    Screen is black, no backlight. Caps look normal. I didnt measure it, I forgot my multimeter in another car.
    Any common issue?
    Thanks...
    05-17-2022, 04:35 AM
  • crewdog
    Hp 15-dy2087nr white lights blinking
    by crewdog
    Board DAOP5HMB8F REV F
    Model OPSH
    No bios battery on board
    Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
    Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
    and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
    Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
    10-25-2023, 03:08 PM
