Lg pdp42x3 no picture, powers off
+ More Options
Posts
  • bdtprez
    • Dec 2012
    I have a PDP42X3 that powers on for a few seconds and then the SMPS turns off. There is never a picture. There are no visibly blown caps, but I did find a blown FS2 on the YSUS board and replaced it but still the same symptoms. Has anyone experienced this before? Does this mean the YSUS is bad? Va at both YSUS and ZSUS is 58vdc and Vs is 180vdc and the manual says they should be 60vdc and 186vdc respectively. I was afraid to adjust them up and risk causing further damage to anything without some expert opinions first.
    Also, is it safe to just unplug the connectors leading from the PSU to the other boards to try and isolate which one is causing the shutdown?
    Thank you so much for any help!
  • drpj23
    • May 2012
    • 528
    Re: Lg pdp42x3 no picture, powers off
    Vs is a bit low but you can adjust with a pot on the power supply.
    Yes, you can separate the YSUS from the psu and see if that is causing your problems.
    There actually should be a sticker on the panel with the required Va and Vs voltages. (The manual could be right but best to go by that sticker)
    • csmith
      Vizio D50u-D1 Powers up no picture
      by csmith
      I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
      Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
      supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
      issue. Set will power up with remote but not power off....
      07-11-2025, 11:52 AM
    • sergio_av
      Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
      by sergio_av
      Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
      Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
      When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
      Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
      01-01-2025, 05:27 PM
    • KYBOSH
      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
      by KYBOSH
      Saved this beast from the landfill this weekend.
      Manfactured July 2013 in Mexico.
      I love working on plasma TVs.
      Its been a while but I was lucky enough to find 2 this week.
      The TV powers on and stays on but no picture. Havent checked for sound yet.
      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
      Will start troubleshooting tonight.
      10-17-2024, 01:17 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • JJAAMM
      by JJAAMM
      Problem
      07-06-2023, 06:01 AM
