samsung pn50a450p1dxza
  • TimT
    • Nov 2012
    • 268
    • us
    Hi everyone, when plugged I hear a click then get very little " white noise " on the screen. then I hear the startup chime then another click, the a solid white " bar " about 5 inches wide appears on the screen going up and down.
    This last for about 3 seconds then the screen turns on " red static " with a bar running across the screen. the green led2 is constantly blinking ( see picture)
    Tested all fuses glass type and SMF all ok.
    checked all connections.
    Dont know were to go from here? firmware?
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: samsung pn50a450p1dxza
    Did you try to use different inputs, different video sources, or different cables?
    Does the menu for the TV work?
    Might be an issue with the x/y boards, user 'tom66' will know...
    -Ben
    Muh-soggy-knee
      Y-buffer very likely. This TV combines the Y-buffer and Y-main into one board.
      This problem is never "alone" X/Y-main (unless buffer is integrated); those boards only make the panel light up and can't cause this problem.
      Unfortunately you will likely need to replace the whole Y-main board.
      • TimT
        • Nov 2012
        • 268
        • us
        Thanks Tom66 I just found the controls. the sound does work. and I can tell the menu does come up. had it on a local channel I can tell the picture is working. i can detect a hint of movement on screen. so it needs a new y-main? " big board on left " y sustain?
          Y-sustain (LG) == Y-main (Samsung) == SC (Panasonic)
          • TimT
            • Nov 2012
            • 268
            • us
            Thank you!
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • Chrissygizmo
              samsung galaxy ao2s very temperamental after screen replaced
              by Chrissygizmo
              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
              Ive eventually managed to get it on and working but it's very temperamental...
              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
              05-26-2024, 12:05 AM
            • Kiberge
              Samsung LH82QENELGC/EN Help needed - Static line on screen
              by Kiberge
              HI guys!
              I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
              I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
              the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
              This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
              04-22-2024, 11:28 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • kotel studios
              Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
              by kotel studios
              Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
              In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
              Today, 02:07 AM
