Philips Plasma 42" 42pf7320/98 after some time goes of
  • pragati_forum
    • Oct 2012
    • India
    When Power on is complete work but after 5 min or 10 min or 20 min or 1 hour
    it of off
    after power of and power on tv is on
    Please help power supply capacitor is look ok
  • bbllchmpn
    • Jul 2013
    Re: Philips Plasma 42" 42pf7320/98 after some time goes of
    Anyone know anything about why this might be happening? I have the same issue with my 42PF7320/98. It remains on for a while(random amount of time) before shutting off on its own. I have to unplug the unit for a bit and plug it back in for it to turn on again. Since the time is random and I haven't been around when it shuts off, I haven't been able to see if or how many times the red light blinks afterwards. I've read in another forum that some people fixed this issue by adding a heat sink on top of one of the chips. I'm not quite sure which chip, though, because the model in that thread had slightly different placements of boards than my model(the model discussed in that thread was the 42PF7320). Also, I already have the back open and all the capacitors seem to look fine. I know that doesn't mean they are actually fine but I don't have a meter at the moment to check each one individually. Any help would be appreciated. Please bear in mind that I'm a beginner at dealing with electricity but I can do simple tasks such as replacing capacitors.
    • bbllchmpn
      • Jul 2013
      I just noticed that the TV doesn't actually turn off, the screen just goes blank but the green LED is still solid. When I press buttons on the remote, I know the TV is detecting the action because the green LED blinks as I press the buttons but nothing is displayed on the TV(if I press the volume up or down, the volume bar doesn't show as it normally would). Again, this is fixed by unplugging the TV for a few minutes and plugging it back in. What do you guys think the problem could be?
      • celiabrown
        Issue with Plasma Philips 37inch chassis FTL2.1
        by celiabrown
        Hello guys,
        My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
        Can someone has any symptom like this ?
        Thanks​
        05-09-2024, 10:56 PM
      • crozoki
        Philips 65PUS6554/12 one time backlight flash
        by crozoki
        Hello
        I have Philips 65" TV (65PUS6554/12).
        Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
        Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
        Power board TPV 715G9187-P01-008-001S
        Main Board 715G9907-M01-B03-005K...
        09-03-2022, 05:47 AM
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
      • titomno2
        Gaming Laptop Zephyrus S17 TFT not detected every time !
        by titomno2
        Hi guys,
        I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
        So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
        On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
        Then the screen won't work for a long period of time.
        If I wait 1 or 2 hours it work again most of the time.
        When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
        01-19-2025, 08:27 AM
      • novak2
        Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
        by novak2
        Hello there,
        I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
        The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
        From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
        Thanks in advance.
        09-25-2020, 02:34 PM
