42LG32000 - Contrast problem, holografic traces, pulsating picture
  • zgchipo
    • Dec 2012
    • Croatia
    Hey everybody.
    I got an malfunctioning 42LG3000.
    It has weird colors like too much contrast, and is hard to get the right skin collor. It is either too red-ish or too yellow-ish.
    Also the picture has traces of menus or logos of tv company that is in same place when i switch programs.
    And now started pulsating every 5 seconds. It pulsates the blacks to almost inverted looking picture.
    I tryed with connectors, but they seem ok. Im not a electronics expert so i looked for mechanical issues.
    No blown capacitors, no black spots, no blown ICs and no cold soldering.
    I tryed everything that crossed my mind even taping and hitting each end every thing on the boards.
    Please help.
    Re: 42LG32000 - Contrast problem, holografic traces, pulsating picture
    Most likely bad panel / bad tab bonds. If it uses Chi-Mei panel VERY likely.
    https://www.youtube.com/watch?v=xHst6pKLtTE
    • zgchipo
      • Dec 2012
      • Croatia
      Thank you for the fast reply, but do you have any other suggestions that i can try,
      I`m no electronics expert but however i`m good with soldering iron but i need to know what and where to check with an multimeter.
      If i put pictures can you tell me where to put which probe, and what should i see.
        This is not something testing with a multimeter can usually fix. Try -very gently- twisting the frame of the TV. If the picture comes back, it is a tab bond issue...
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • MikeRWK
          Sharp LC-32D40U Negative picture unless the contrast is almost 0
          by MikeRWK
          This only affects the picture but not the tv menus. Selecting any of the default picture settings gives a negative picture but turning the contrast down to 5 'fixes' it but then the tv is too dim which is hard to tell in the pictures.
          This tv has a main board, scaler board, and a tcon.
          I tore it down so I could probe the tcon which is nicely labelled. I've also included a pic of it.Here are the voltages I got:
          VGH 32V
          VGL -6V
          GAM1 14.6V
          GAM18 185mV
          VLS 14.67V
          3V 3.01V
          RESET 2.95V
          TCLK 0V
          SCC_VDD...
          01-30-2021, 05:21 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
