LG 42PC5D, No picture just sound. $30 yes or no?
  • johnboy1313
    • Nov 2012
    • 1959
    I found a 42PC5D locally. No picture, just sound. The owner says there is no flicker, there is nothing at all in regards to the screen. I have fixed 4 of 5 LCD TVs and diagnosed the 5th as being too expensive to fix. I have never worked on a Plasma but I'm not intimidated by it. If I can get it for $30 should I? Thanks
  • drpj23
    • May 2012
    • 528
    Re: LG 42PC5D, No picture just sound. $30 yes or no?
    You probably wont get much for it in resale (due to it being an older plasma and a 720 set) but if you want to get familiar with plasmas and try to understand the operation of the set then sure.
    You probably have a problem with the hybrid in the Y sustain.
    • johnboy1313
      • Nov 2012
      • 1959
      That's what I've read. I'm not even sure what a hybrid is. Any chance someone could post a pic?
      • drpj23
        • May 2012
        • 528
        Here check this out.
        http://blog.coppelltvrepair.com/search?q=42pc5d
          These also have sparklies bugs (needs firmware update -- difficult to do), but $30 is cheap, so may be worth it.
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Mgiffune
            by Mgiffune
            06-09-2024, 10:28 AM
          • Ierwin
            by Ierwin
            05-13-2025, 03:31 PM
          • jchang
            Samsung UN70NU6900F no picture and no sound
            by jchang
            Hi all
            I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
            Symptom:
            No picture no sound.
            When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
            No sound at all.
            What I tried:
            1. I tried unplugging the left or right ribbon...
            01-09-2023, 06:28 PM
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
