Anyone need anything off a Mitsubishi LT-46149?
  • johnboy1313
    • Nov 2012
    • 1959
    I hope this isn't against the rules. You guys have helped me out a lot. I have a mits lt-46149 with a bad panel. Everything else works like it should. I thought I might keep it around and look for a newer panel for it but I've changed my mind. If you need anything off it, let me know and I'll get you the sticker numbers. Just shoot me an offer. I'm not trying to get rich off this thing. I'll get pictures of everything this afternoon with part numbers.
  • hugocarmo
    Mitsubishi HS-E82 VCR Bad Picture
    by hugocarmo
    Good morning everyone.
    This time I have a Mitsubishi HS-E82.
    It was a bargain that I found with original remote included.
    The problem reported by the owner is that it was working but no output video.
    I took it appart and immediately saw that three 470uf capacitors were leaking on the signal board and one in the Hi-Fi board the same value too. I have located them in the pictures in red marker.
    I replaced them, cleaned all the liquid remains and the video output got working again.
    I saw too that were three surface mounted capacitors, two near the 470uf and...
    11-21-2023, 04:11 AM
  • sikocan
    Help identify chip MITSUBISHI ELECTRIC Air-Conditioner Network system
    by sikocan
    Looking for a component labelled 56 on top 59 on bottom. It's from a MITSUBISHI ELECTRIC Air-Conditioner Network system. Thanks!...
    06-13-2023, 08:16 PM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
  • michalk3777@gmail.com
    Looking for discontinued Mitsubishi MCU - M306N1MCT
    by michalk3777@gmail.com
    If this is not correct forum I apologize, I looked on the store page but did not see anything even close to this.
    I need help finding a replacement MCU. Its from a Seadoo gauge cluster. Made by Mitsubishi, part No. M306N1MCT-203FP (bottom one on the picture, specs. attached). Cannot locate it anywhere. If anyone can point me to where I could find one in either USA or Canada that would be greatly appreciated.
    Regards,
    Michal...
    09-03-2022, 12:30 PM
  • Keshenatech1
    Mitsubishi LT-52149 help
    by Keshenatech1
    Has anyone out there had any experience with the Mitsubishi LT-52149? (The LT-46149 is identical and uses the same main and power boards, just a smaller panel) I have one that is very intermittent and normal logical troubleshooting steps are not working for me. The set came in with a no sound/no picture problem. After I hit the reset button on the control panel, I got it to come on one time. Snowy screen and loud static in the speakers so I hit the input button to try to switch to an HDMI to quiet it down. It said it was adjusting something and then just shut down. I held the menu and input buttons...
    12-20-2020, 11:03 AM
