Lcd tv power supply producing a high pitched and static noise. No picture but sound.
  • efan
    • Sep 2012
    • 30
    • CANADA
    Re: Lcd tv power supply producing a high pitched and static noise. No picture but sou
    fuses as shown in picture
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by budm
      B+ of 36 Volt seems very high.
      Agreed.
      @funtastic, you want to measure DC voltage with your black probe on either a ground screw on the t-con or chassis.
      --- begin sig file ---
      --- end sig file ---
      • funtastic
        • Nov 2012
        • 63
        • New Zealand
        Hi There,
        I've tested all four of the white fuses and they are fine, and tested other components, and the caps. Everything is receiving around 36v. The black fuse is the one that has blown.
        Shall I buy the same fuse as on this thread? https://www.badcaps.net/forum/showthread.php?t=17214. Seems like the same fuse.
        Do you think 36v is to high? What would cause a higher output?
        One other thing is that the fan above the power supply isn't working. I checked the connector and it's not receiving power, or is it one that switches on when it gets to a certain temp?
        Thanks all for the help.
          I expect that black fuse to be bad, very common on this CMO board. I use through hole PICOII fuse by just bending the legs. One end of the fuse is connected to the 24V input, you can just trace another end to the solder pad that the other end of the fuse is connected to. You should verify you meter first with know good batteries such as car batteries.
          • funtastic
            • Nov 2012
            • 63
            • New Zealand
            Thanks for that. I replaced the multimeter battery and it's now 24v.
            Could you please link me to the fuse to get on Digikey please? The label of this fuse is F 1A/76v.
            • funtastic
              • Nov 2012
              • 63
              • New Zealand
              #26
              Will this be fine? http://www.ebay.com/itm/10pcs-Littel...item5d35fbb91e
              Would like an answer please to my previous question about the fan.
              • funtastic
                • Nov 2012
                • 63
                • New Zealand
                #27
                Anybody?
                • funtastic
                  • Nov 2012
                  • 63
                  • New Zealand
                  #28
                  With the PICO Fuse is there a positive and negative or can it be put on any way?
                    There is no polarity in the fuse. That one on EBAY is the type I use. I get my from Mouser, but Digikey also sell them.
                    http://s807.photobucket.com/albums/y...%20Littlefuse/
                    What is the smallest value resistor in 1/4 w size you have? If you have anything less than 1 Ohm, you can use that for testing for now. Not sure about the fan.
                    • funtastic
                      • Nov 2012
                      • 63
                      • New Zealand
                      #30
                      Hi All,
                      I replaced the fuse and the back light flicks on for a second and then turns off again but the picture and sound are still on.
                      What else could be wrong?
                        One of the transformers or bulbs could be faulty.
                        Do the transformers have a part code on them?
                        • funtastic
                          • Nov 2012
                          • 63
                          • New Zealand
                          #32
                          Hi All,
                          Thanks for every ones help . Turns out that I forgot to plug in a tiny connector on the inverter and now everything works like new.
                          • funtastic
                            • Nov 2012
                            • 63
                            • New Zealand
                            #33
                            Hi, the fan connector isn't receiving power and was wondering if it was possible to connect the wires up to somewhere else on the circuit boards?
                            The connector is the one at the top right of pic.
                              Did the fan always run before the TV broke down? May be it is on only when the sensor senses too much heat?
                              • funtastic
                                • Nov 2012
                                • 63
                                • New Zealand
                                #35
                                Hi, I bought it with it not working. I thought that too so I left it going for 2 hours and it felt quite hot and still the fan hadn't come on so I'm unsure whether it wasn't hot enough or there's something wrong. Maybe I should leave it going for longer and see what happens.
                                If it still doesn't come on is there a place that I could wire it in? strip two of the wires of the ones connecting to that board?
                                  Does the FAN has two wires or 3 wires? Voltage and current rating on the Fan?
                                  • funtastic
                                    • Nov 2012
                                    • 63
                                    • New Zealand
                                    #37
                                    3 wires but the third is just the speed reading correct? 12V and 0.09A
                                    • funtastic
                                      • Nov 2012
                                      • 63
                                      • New Zealand
                                      #38
                                      Not sure if you need these reading but thought I'd list them.
                                      Top left connector
                                      1. 12.39
                                      2. 0.00
                                      3. 0.00
                                      4. 0.00
                                      5. 15.21
                                      6. 0.00
                                      7. 6.18
                                      Next connector down
                                      1. 0.00
                                      2. 11.11
                                      3. 0.00
                                      4. 5.00
                                      5. 0.00
                                      6. 1.74
                                      7. 0.00
                                      8. 3.27
                                      9. 0.00
                                      10. 5.00
                                      11. 0.00
                                      12. 0.00
                                      13. 4.87
                                      14. 4.87
                                      • funtastic
                                        • Nov 2012
                                        • 63
                                        • New Zealand
                                        #39
                                        Don't worry about it now I connected the fan to the first connector onto the first two pins and it's working great.
                                          Glad it works out, failed TV due to 50 cent fuse on the inverter board.
                                          • Comp_Pro
                                            Macbook Air 820-00165 Static Chime Sound
                                            by Comp_Pro
                                            Hello all,
                                            I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
                                            11-02-2023, 03:23 PM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • diggitt
                                            Radio, no stations, quiet static sound
                                            by diggitt
                                            I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
                                            04-14-2025, 05:06 AM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
