Re: IC Number on DPS-286 AP/RDENCA336WJQZ Sharp power board
It blew open circuit because you have shorted component on the output side of the R7914, check the resistance of the STBY SMPS IC7905 PIN 8 and Primary circuit GND for very low resistance.
Did you replace all the components or only the R7914? when i replace the R7914 always blows.Leave a comment:
I just wanted to say thanks for this thread, it got by DPS-286ap up and running again. I ended up replacing R7914 (failed open), R7918 (seemingly OK at 2.2ohm), IC7905, D7908, and D7905 (showing around 400ohm).Leave a comment:
Hi, I have Sharp LC-42A66M and having intermittent power off problem. TV will shut off of a few seconds[no green/red light at front LED] and it came back. It happens once/twice a day. And, sometimes no problem for a few days.
I though it was bad cap and opened up and checked the power supply board.
But, there was no bloated cap on board.
Power supply board is DPS-226AP-1 (RDENCA340WJQZ)
Is it possible that TNY264AP is having intermittent issue?
Should I just replace it?
Thanks in advance.
I was able to open the PDF, but it was one page without specs of any of the parts in the diagram. I ordered both some 1/2W and 1/3W resistors. I'm not sure what to install in the board. I did find some 1/4W resistors on another website that I can order, just not sure if I need to.Leave a comment:
http://www.electronica-pt.com/esquem...s-304bp-25419/
schematic dps 304Leave a comment:
R7918 still test good along with D7908 and D7909. How do I determine if it is a 1/4W or a 1/2W? Looking on Digi-Key they are the same physical size. It looks like they have the 1/2W in stock, and can order them individually, but I would have to buy 5,000 of the 1/4W to order them.Leave a comment:
R7914 is the 2.2 OHMS FUSIBLE resistor 1/4W (or 1/2W, you have to measure the dimension) for supplying B+ to run the STBY power supply section, (you can use 2.2 Ohms MOX type which is Flame proof )that will blow open when that SMPS IC for the STBY power supply shorted out. R7918 is still OK?
Sharp RDENCA235WJQZ (DPS-304BP-1) Power Supply Unit
http://www.shopjimmy.com/sharp-rdenc...pply-unit.htm#Last edited by budm; 01-22-2016, 09:57 PM.Leave a comment:
I have a DPS-304BP-1 A power board from a Sharp LC-42D64U with a blown IC7905 and a bad R7914. I can't seem to find info on the resistor. This thread sounds exactly like mine. The resistor is a 2.2 ohm resistor, I'm just unsure of what kind it is and where to get one. Can someone help me find what type of resistor I can replace it with? Thanks.Leave a comment:
You can disconnect the cable between the power supply and the main board to see if that standby Voltage will come up. If not, then we need to do more troubleshooting in that power supply section.Leave a comment:
Both diodes replaced with the same numbers labeled. Still no stand by power. Probably main board?Leave a comment:
Sorry I only replaced d7909 d 7908 tested good off the boardLeave a comment:
"I've replaced both diodes with same reference number 5383b"
D7908 and D7909 are NOT the same. Please look at the original diode D7909.
D7908 is 150V ZENER DIODE 1N5383.Last edited by budm; 10-24-2015, 07:25 PM.Leave a comment:
I have 165vdc from negative of cap to r7914 and r7918. Also from cap to D7908 D 7909 4vdc and 5 Vdc on other side. I've replaced both diodes with same reference number 5383bLeave a comment:
1/2W. Is it open? That section of the circuit if for supply the VCC to run the PFC and the 12V/24V SMPS.
I updated my post 48.
So you still do not have the standby Voltage? Snubber diodes are OK?
BTW" Yes replaced that board still nothing" you replace the whole power supply board?Last edited by budm; 10-23-2015, 07:44 PM.Leave a comment:
Yes replaced that board still nothing but do you know what wattage is r7914 the 2.2ohm resistorLeave a comment:
TNY264AP. The resistor R7918 2.20 Ohms is 1/2W MOX Flame proof, it is for supplying the Voltage from AUX winding of the STBY transformer for running the PFC IC and the SMPS IC of the 12V/24V power supply. The R7914 is the fusible resistor for supplying B+ to run the IC.
You also need to check the snubber network D7908, 7909.
So do you have about 165VDC between the negative leg of the main filter cap and either legs of R7914?
DCV between the two legs of the running cap C7915?
pictures provided by shopjimmy.
http://www.shopjimmy.com/sharp-rdenc...pply-unit.htm#Last edited by budm; 10-23-2015, 07:40 PM.Leave a comment:
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
