Sony KDL-55XBR8 vertical lines
  • Sevenqi
    • Jul 2011
    • 292
    Sony KDL-55XBR8 LCD TV, 55" inches, manufacturing date Feb 2008.
    Problem: vertical lines all the screen, same pattern, these lines appear almost all inputs except the VGA signal from computer, but the internal pictures (sush as menu, TV guide,etc.) has no lines in front but they are beind the pictures, as show in the second photo.
    Wondering if this is the main board problem, but why VGA is good ? (I haven't tried components yet, but I think should have the same issue).
  • drpj23
    • May 2012
    • 528
    Re: Sony KDL-55XBR8 vertical lines
    Main is probably at fault, since one input doesn't fit symptoms and OSD is unaffected means TCON is doing it's job correctly.
    • Sevenqi
      • Jul 2011
      • 292
      I'm sure it's the main board problem, but board is very expensive (around 200in ebay, 450 in Sony parts). I did a research for this model, it has a Digital Reality Creation (DRC) setting in Picture Adjustment menu, I tried to set DRC to off, the lines disappear!
      Some Sony HDTV tvs have a processor that "upconverts" lower quality "standard" inputs to near hi def quality, I think the processor is bad and created the vertical lines.
      • Sevenqi
        • Jul 2011
        • 292
        This works for me for half year, everything looks good.
          Digital Reality Creation may be something to do with MotionFlow -- frame interpolator. I've have lots of issues with the interpolator processor BGA solder joints failing -- common fault due to lead free solder.
          • supra87
            • Jul 2013
            i m new member supra 87
            my reply is for sony kdl-55xbr8 vertical line
            the photo of sevenqi member post 9311-24-2012 03;16pm
            i have same model and same pattern line and the problem was
            the hdmi connection
            the port 1 & 4 do that problem and 2 & 3 was ok
            i hope this help
            • lynnsharpe
              • Jun 2015
              • 3
              I have a Sony KDL-55XBR8 that was showing vertical lines but when I changed the picture mode from standard to custom, the lines disappeared. Going back to standard mode the vertical line reappear. I'm guessing the main AU board has problems, but at least I am able to use in "custom" mode. Any thoughts from other Bravia owners?
              • lynnsharpe
                • Jun 2015
                • 3
                I have attached photos of the Sony KDL-55XBR8 in each of the four picture modes, i.e. cinema, vivid, standard and custom. As you can see, the only mode without vertical lines id the custom mode. Source was a DVD playing a movie via an HDML connection. I had just changed out the AU 1-877-616-11 main board, but no solution. I also used all the other html connection but that didn't help. Thought it might be the TCON board but overlay menus show no sign of the lines but in the background the lines are visible. Have any of you experienced any thing like this?
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
                • gpo23
                  Sony KDL-40V3000 - Vertical lines
                  by gpo23
                  i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                  With the new t-con the color are good but there are vertical lines on all the screen :
                  I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                  Is there a way to fix the vertical lines on the new t-con ?
                  Thank you for your help
                  gpo23...
                  10-04-2023, 09:11 AM
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • noisykid
                  Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                  by noisykid
                  5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                  12-30-2024, 07:15 PM
                • dustman1747
                  Sony XBR-65X900H vertical lines
                  by dustman1747
                  I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
                  Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
                  09-18-2023, 09:05 PM
