p50 hdtv20a
  • acuser
    • Nov 2012
    • 18
    • usa
    p50 hdtv20a
    Vizio p50 hdtv20a
    No picture
    No sound
    plug in set amber light is on
    push power button light turns green and stays on
    Here is a little difference from what ive found in my searches, when I try
    to turn set off with power button it just stays green. The only way I can turn off is to pull plug.
    Normally it looks like the likely problem is y sus and buffer boards, but Im hopeful
    with the set not powering off it could be the main board(0171-2272-2302)
    Appreciate any help
    ps. I have pushed the input button multiple times and hear no sound, is this the correct procedure when you say cycle through inputs?
  • IamCanadian
    • Nov 2012
    • 119
    Re: p50 hdtv20a
    Post pics of the inside of the TV (using the attachment manager) Show full tv with back off, a Power supply pic, and main board pic at least.
    Do you have a Digital Multimeter?
    • acuser
      • Nov 2012
      • 18
      • usa
      Re: p50 hdtv20a
      I took about 20 different pics these were the best ones.
      yes I have a meter
      • IamCanadian
        • Nov 2012
        • 119
        Re: p50 hdtv20a
        The pics are poor, You should use a proper camera. Does the PSU have labels for voltage? If so check to see if voltage is as what is marked on the pins.
        • IamCanadian
          • Nov 2012
          • 119
          Re: p50 hdtv20a
          http://www.tgohome.com/ServiceManual...ngLCD_[SM].pdf
          That should be the service manual.
          • acuser
            • Nov 2012
            • 18
            • usa
            Re: p50 hdtv20a
            OK checked all pins I could find. Are their others?
            vs=209.1
            va=63.2
            a12v=12.15
            vamp=23.9
            vt=32.8
            d5v=5.15
            d3v3=3.5
            • IamCanadian
              • Nov 2012
              • 119
              Re: p50 hdtv20a
              does the VS VA and VT voltage stay on for the entire time that the green light is on? or does it go away after a few seconds of being on?
              I should also ask if any caps look bad?
              • acuser
                • Nov 2012
                • 18
                • usa
                Re: p50 hdtv20a
                power on for about 5 mins the vs va vt still have same voltage
                • IamCanadian
                  • Nov 2012
                  • 119
                  Re: p50 hdtv20a
                  And nothing on screen at all? in a dark room their is no glow?
                  • acuser
                    • Nov 2012
                    • 18
                    • usa
                    Re: p50 hdtv20a
                    dont see any bulging or leaking caps
                    • acuser
                      • Nov 2012
                      • 18
                      • usa
                      Re: p50 hdtv20a
                      didnt even notice that before there is a very faint glow
                      • Frank O
                        • Nov 2012
                        • 4
                        Re: p50 hdtv20a
                        Ok, so I don't a clue but I'm hopping that I get to learn about electronics.
                        • IamCanadian
                          • Nov 2012
                          • 119
                          Re: p50 hdtv20a
                          I would think it is the main board, But I would wait for a much more informed forum member to confirm anything.
                          • acuser
                            • Nov 2012
                            • 18
                            • usa
                            Re: p50 hdtv20a
                            ok Thank you very much for your help.
                            • acuser
                              • Nov 2012
                              • 18
                              • usa
                              Re: p50 hdtv20a
                              anyone care to confirm IamCandian's diagnosis?
                              • acuser
                                • Nov 2012
                                • 18
                                • usa
                                Re: p50 hdtv20a
                                Could any one confirm IamCanadian's diagnosis before I buy the board.
                                • drpj23
                                  • May 2012
                                  • 528
                                  Re: p50 hdtv20a
                                  Check the regulators on the main board - Vizio is plagued with this - the fact it does not turn off may lead to this.
                                  A primed panel is a good sign though.
                                  Is there a fuse on the CTRL board? (That is the board behind the main)
                                  • acuser
                                    • Nov 2012
                                    • 18
                                    • usa
                                    Re: p50 hdtv20a
                                    I found 2 of what I recognize as regulators. One has three legs which checked from center to one side at 12v and center to the other side at 5v. the other regulator had three legs but the center one was cut off it checked 3.3v. Im not sure the two legged one is regulator although it looks like one without the heat sink.
                                    The only thing that looked like fuses were small white rectangles with copper or brass caps on the ends, these checked out ok. There were also three of these on main board that checked ok also.
                                    Sorry for my lack of knowledge. I do appreciate your help. It would be awesome if I could get this thing working.
                                    Any other Ideas for this wannabe tv tech?
                                    • drpj23
                                      • May 2012
                                      • 528
                                      Re: p50 hdtv20a
                                      Here, I circled some to test.
                                      Report it by posting the component location then part number and then voltage on each pin.
                                      • acuser
                                        • Nov 2012
                                        • 18
                                        • usa
                                        Re: p50 hdtv20a
                                        do you want those to be checked from each pin to ground? or from the center pin to the outside pins?
                                        I have all the numbers from each pin to ground but wasnt sure if that was what you wanted.
                                        Thanks for your help
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first β€˜decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
