Sceptre X32 Power Supply Diagnosis
    Re: Sceptre X32 Power Supply Diagnosis
    That is correct but you must complete that connection after the power switch is activated this is to allow the power supply to stabilize before turn on the inverter which draws lots of inrush current.
    You must make sure the wire on pin 12 is NOT connected.
    • urfavtech
      Noobie
      • 11
      Long time no reply Budm, I apologize for that, this project got put on the side for awhile, however I just started working on it again.
      We left off with me jumping the 5vSTBY on power board to pin 12 BL_ON on inverter board, since this project has been around for a year, I went ahead and bought a used main board, slightly different model, but everthing lines up the same.
      Here is what I am currently running into now:
      Hit power button, blue light comes on, back light does not.
      Unlike before, I am able to turn the tv back off without unplugging it from power, with another push of the power button.
      SO... back light not coming on, I went a made a jumper from the 5vSTBY to pin 12 on inverter with a 120 ohms resistor, and the back light did not come on.....
      Before the back light would come on temporarily when i hit power button, but then back off, leaving blue light still on in which the power button would not turn tv back off without unplugging... now i get no backlight at all with new main board.
      If you would like to pick up where we left off, this is where I am at on the project. Thanks ahead of time
      sigpic
      • Eqwipman
        • Aug 2016
        • usa
        #43
        Hi, I am new to this forum and I want to comment on this thread. I too have a scepter x32 with the same problem. after disassembling the TV I powered it up with the LCD screen attached and I could see the video so that is working. the backlights (one of them) come on dimly and then fade to nothing in a few seconds. the voltage was 20 but it keeps dropping. I think the problem is in the 24v supply. haven't troubleshot it yet but I will soon. looks like a common problem with this TV. if I come up with a solution it will let you know.
        • bossman696
          • Oct 2016
          Hello, I am new to the forum as well and have a Sceptre X325BV-FMDR which seems to just be a variant of the model in this thread. The unit will turn on and doesn't show a picture but I do have sound. I did the flash light test on the screen and can see an image which seems to confirm the backlights are now working. I have been told on other models there is an investor board to replace, but don't know enough about this model and can seem to find whether there is a separate investor board. Any idea as to what board or part I should replace? I don't know enough about soldering to get into replacing capacitors and would like to avoid that if I can buy just replace the whole component. Any help would be greatly appreciated.
            by sam_sam_sam
            03-31-2024, 02:12 PM
          • navagator
            Hitachi Power Supply Unit Interchangeability
            by navagator
            I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
            Does anyone know if these 2 power supply boards are interchangeable?
            Thanks.
            01-08-2024, 07:53 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
