LG 42PC1DA Plasma Sound but blank screen
    Re: LG 42PC1DA Plasma Sound but blank screen
    OK, across any of the 5 red capacitors (bottom left) you should have around 60-100V if the Z-sustain is working.
    • ghiotom
      • Oct 2012
      • 41
      Are you sure you're getting 15V at the IPM on the Zsus board?
      • LesWoollam
        • Nov 2012
        • 69
        • United Kingdom
        #43
        There's 162v across the 5 x capacitor bank.
        15v is getting to the Z-sus IPM.
          Hmm, 162V seems too high, what is Vs for this set?
          • LesWoollam
            • Nov 2012
            • 69
            • United Kingdom
            #45
            VS 186v; VA 60v
              I suppose, as it is not at full Vs, or 0V, that it is not shorted out, but I am really confused by why you don't have any picture at all. Apart from the ramp wave on the Z-sustain everything appears OK.
              • LesWoollam
                • Nov 2012
                • 69
                • United Kingdom
                #47
                Could it have anything to do with the X-Board?
                  Do you mean the Z-sustain or the panel X buffers? It's unlikely to be the panel X buffers, as they usually cause stuck lines or blocks of pixels when they fail.
                  • ghiotom
                    • Oct 2012
                    • 41
                    Even with the Zsus board disconnected, you should get a dim image on the screen.
                    • LesWoollam
                      • Nov 2012
                      • 69
                      • United Kingdom
                      #50
                      Yes, I did mean the X buffer board.
                      Even with the Z-sus board removed the screen is completely blank.
                        This makes me worry the panel is bad. Is it making a buzzing/crackling sound, like someone rapidly tapping on glass?
                        • LesWoollam
                          • Nov 2012
                          • 69
                          • United Kingdom
                          #52
                          I was beginning to have the same thought myself. However, there is no sound coming from the panel.
                            Either way something isn't right with the Z-sustain and I'm not sure why.
                            • LesWoollam
                              • Nov 2012
                              • 69
                              • United Kingdom
                              #54
                              If the panel has gone would that cause the Z-sus board to be cold but the Y-sus board warm as normal?
                                Normally neither board would be warm.
                                • LesWoollam
                                  • Nov 2012
                                  • 69
                                  • United Kingdom
                                  #56
                                  So is the X-sus board getting warm a sign the panel is OK?
                                  • ghiotom
                                    • Oct 2012
                                    • 41
                                    Have you ruled out the Y-Buffer board? If all of your DC voltages are correct and you have the correct waveform coming out of your Y-Sus board, could the buffer board be the problem? BTW, I have a working 42PC3D, which is similar to yours, cracked open on the bench in case you need me to make any comparison checks.
                                    • LesWoollam
                                      • Nov 2012
                                      • 69
                                      • United Kingdom
                                      #58
                                      I assume the Y-buffer board is the long board on the left (sometimes called the Y-drive board)?
                                      If that's the one, it has 10 x scan ics which would all have to have failed to leave the screen blank wouldn't they?
                                      How can I test the Y-buffer board?
                                        This link has a test you can perform:
                                        http://blog.coppelltvrepair.com/2010...er-boards.html
                                        It's for a Samsung but it should be similar for LG.
                                        • LesWoollam
                                          • Nov 2012
                                          • 69
                                          • United Kingdom
                                          #60
                                          Performed the test on the buffer board and all scan chips check-out OK. However, on listening very closely to the screen I can hear a faint buzzing sound - certainly not like glass being tapped, but nevertheless there is a buzzing sound. Sounding like a dead panel?
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • triplefour
                                            TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                                            by triplefour
                                            Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                                            no change to display when disconnect tcon
                                            no change to display when disconnect panel cables (both sides, one at a time, etc-)
                                            can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                                            also can faintly see a black cloud in the center of the screen. a darker area.
                                            color of screen is backlit black screen which basically looks gray
                                            12v present at TCON fuse
                                            other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                                            10-28-2021, 01:00 AM
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
