Panasonic TC-P42X2
    Re: Panasonic TC-P42X2
    Are Q001, Q002 in parallel? How about Q021, Q022? If so, lift a leg and test each individually.
    At $28, I would just say "screw it, I'll replace the board":
    http://www.ebay.com/itm/PANASONIC-TC...item27ccb797f1
    ...you'll spend too much replacing those to find you've got more faults like a blown MOSFET gate driver. (15V gate driver gets 200V shoved into output pin and it ain't happy one bit about that.)
    • IamCanadian
      • Nov 2012
      • 119
      I checked them out of C
        What do you mean out of "C"?
        There are more where that came from for nearly the same price:
        http://www.ebay.com/itm/PANASONIC-TC...item2c69a83c1f
        http://www.ebay.com/itm/PANASONIC-TC...item27ccb852da
        http://www.ebay.com/itm/SANYO-DP5071...item27c63fdfc7
        http://www.ebay.com/itm/SANYO-DP5074...item2c66e41aae
        http://www.ebay.com/itm/SANYO-DP4274...item2ec0df09ca
        • IamCanadian
          • Nov 2012
          • 119
          Tested them with S and G legs up.
          I am going to check the SN the same way and if it needs them too, I will just buy a SN and SS..Prob be cheaper haha
            You only need to lift S but that is pretty good indicator, the FETs are fried. Likely one failed which took out all four. Hopefully the SN is fine -- they rarely fail simultaneously. What is the part# of SN?
            • IamCanadian
              • Nov 2012
              • 119
              TNPA5066 42.00 from same supplier as the SS
                Plus $15 shipping though I suppose they might combine the shipping with the other one. Pretty pricey, does set start up with just SN? (it will likely throw 8 blinks for missing SS but if it doesn't do 4 blinks then there's no short.) How much was your bartered GPS worth for you?
                • IamCanadian
                  • Nov 2012
                  • 119
                  Does not start with just SN with ss and sn unpluged it shows 7 blinks
                    SN may be short I wouldn't know why they both failed though, it's very rare.
                      One thing to try with both boards missing you should get 200V for a couple of seconds, with boards plugged in but no short you should still see 200V, so if SN is not shorted, 200V should be present.
                      • IamCanadian
                        • Nov 2012
                        • 119
                        With everything but the SS pluged in, when power cord is inserted, I get 2 clicks of the 2 switches and red led on front on solid, SPDIF light is visable for 1 second then .5 seconds after SPDIF light goes out the switches in the psu shut off, Leaving only stand by power.
                        after power is plugged in for about 20 seconds the front led flashed rapidly for about 30 seconds.....not a code flash I would say it is about 5-6 flashes per second.
                        • IamCanadian
                          • Nov 2012
                          • 119
                          Yes with both boards out, I get about 165v for a few seconds.
                          Is it possible that something is failing on the PS and just can not supply the Amperage to run?
                            165V? Are you sure? That's quite low for a plasma.
                            • IamCanadian
                              • Nov 2012
                              • 119
                              Yup 165v for sure on Vsus without SS and SN connected. and 0v with either one connected.
                              But the SN does not show a dead short so you would think you would see some kind of V with just the SN connected.
                                What does the sticker on the plasma panel indicate for Vsus? I have only ever seen a low 175V Vsus on an old NEC/Pioneer plasma panel.
                                • IamCanadian
                                  • Nov 2012
                                  • 119
                                  No sticker showing voltages. Panel is MC106H30U13
                                    Very odd. Is there a Vsus adjust pot? Maybe this is the "NeoPDP" Panasonic keep going on about... single piece of glass, lower power consumption, and cheaper to manufacture.
                                    • IamCanadian
                                      • Nov 2012
                                      • 119
                                      VR251 is right next to the vsus discharge pin so it would appear so, I know the Vsus is adjustable from the service menu with low and high as the options.
                                      TV was built Oct 2010...wonder if I can call pana and nag them for a new one
                                        Try it! It's just past 24 months, Panasonic generally like to keep customers "in the brand" and will often replace the TV or repair it for free.
                                        • IamCanadian
                                          • Nov 2012
                                          • 119
                                          Did a little more poking around, When the the SN board is connected (it is not shorted) I get an instant 5v on the sos4 it seems like as soon as their is a load on the vsus the psu just shuts down.
                                          I may be reaching but I just have a feeling that the problem is in the ps.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • AquaMan Ua
                                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                                            by AquaMan Ua
                                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                            05-17-2025, 09:40 AM
                                          • signal.quest
                                            Panasonic TC-P42S30 - Solid RED LED - No Blink
                                            by signal.quest
                                            Hello. I am hoping the very smart helpful people of this forum can help me repair my TV. Here is the history of the what I have done so far.
                                            I was given the TV by a friend who was going to throw it away because it did not work.
                                            The TV definitely had a bad TNPA5349 board that was shorted across the power input. I sent it to a repair service on ebay and was told it was rare case and not repairable.
                                            I then bought a refurbished TNPA5349. Before installing it I checked for a shorted power input and it was good. I installed it and powered on the TV. I could...
                                            02-01-2021, 11:01 PM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • stecos
                                            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                            by stecos
                                            Hi everyone!
                                            I happened several times, in the search for help from the web, to consult this very interesting forum.
                                            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                            Having said that I come to the gist of my post on the forum as the title suggests.
                                            For my passion for technology I'm now collecting several...
                                            11-28-2022, 11:39 AM
