Panasonic TC-P42X2
  • IamCanadian
    • Nov 2012
    • 119
    Panasonic TC-P42X2
    Just got the tv delivered, Red led on solid. off and on again after holding power button for 3 seconds..
    Any thoughts? while I take the back off?
    Re: Panasonic TC-P42X2
    Count the blinks from the LED. May only be one blink.
    • IamCanadian
      • Nov 2012
      • 119
      No blinks at all, going to check for stb power and pwr on signal.
      • IamCanadian
        • Nov 2012
        • 119
        I am working off of a TC-P42S2 training manual for now, I would think it should be close to the same.
          If you have red light, you have stby power.
          I am trying to find the manual for you.
          • IamCanadian
            • Nov 2012
            • 119
            Ok, Also when I plug it in, red light comes on solid for about 5 seconds and then rapidly flashes for about 30 seconds. and I do hear relays when cord is first pluged in.
              Red light goes green flashing, or flashes red? If it flashes red, you need to count exactly how many times. The TV is trying to tell you where the fault is.
              I have found the manual and will shortly upload it.
                Manual:
                http://www.tgohome.com/ServiceManual...&Search=Submit
                Page 17 has your blink codes.
                • IamCanadian
                  • Nov 2012
                  • 119
                  It is for sure not a fault code, it is red, and flashes about 150 times with no gaps.
                  Thanks for the manual, I will report back soon with pics.
                    Very odd. Try in a dark room -- maybe panel is lit up but has no video?
                    • IamCanadian
                      • Nov 2012
                      • 119
                      I will try....but Their is no real reaction when the power button is pressed.
                      • IamCanadian
                        • Nov 2012
                        • 119
                        the problem seems to be in the A board on the 15v side of things.
                        When a6 is unpluged the PSU stays on showing all the right voltages.
                        • IamCanadian
                          • Nov 2012
                          • 119
                          On more testing, It gives codes until any part of the SN has a power plug on it.
                          Almost like the PSU kicks out so fast with the SN plugged in the a board just cant make a fault code for it. Does that sound right?
                            Sounds like a dead short SN. Check across SN power connector; should be >10kohm.
                            • IamCanadian
                              • Nov 2012
                              • 119
                              I pulled all the boards so I can do a better test, Broken leg makes it hard to shuffle around the tv,
                              Anyway, it is the SS board with a dead short, On p11 vsus shows dead short 15v is ok.
                              on SN3 all show as short. What should I start looking at?
                                Do you know how to test a MOSFET? This board primarily uses IGBT and MOSFET. They can all be tested like a MOSFET.
                                Also what is the part number. Should be something like TNPAxxxx. Sometimes the SS can be cheap enough that replacing it works out better than repairing it.
                                P.S. Most Panasonic TVs can be mounted on the floor stand and serviced upright (good design!) Ask a friend to help. Get well soon with the leg!
                                • IamCanadian
                                  • Nov 2012
                                  • 119
                                  PN is TPNA5072.
                                  To test a MOSFET put neg lead on source, POS on gate to charge it, move pos to drain, should be a low reading. Touch the leads with your finger to discharge and reading should go high.
                                  That is how I was told, do you have a better method?
                                  P.S. The guy forgot the stand, but is bringing it later today
                                    No, you can just test across source and drain for shorts.
                                    • IamCanadian
                                      • Nov 2012
                                      • 119
                                      out of circuit right? or can I just lift the S leg?
                                      • IamCanadian
                                        • Nov 2012
                                        • 119
                                        Tested It shows all of RJP30E4 are dead short between S and D.
                                        The 2 RF1501 show low resistance but not shorted.
                                        So Q001, Q002, Q021, Q022 are all shorted
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                                          by AquaMan Ua
                                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                          05-17-2025, 09:40 AM
                                        • signal.quest
                                          Panasonic TC-P42S30 - Solid RED LED - No Blink
                                          by signal.quest
                                          Hello. I am hoping the very smart helpful people of this forum can help me repair my TV. Here is the history of the what I have done so far.
                                          I was given the TV by a friend who was going to throw it away because it did not work.
                                          The TV definitely had a bad TNPA5349 board that was shorted across the power input. I sent it to a repair service on ebay and was told it was rare case and not repairable.
                                          I then bought a refurbished TNPA5349. Before installing it I checked for a shorted power input and it was good. I installed it and powered on the TV. I could...
                                          02-01-2021, 11:01 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
