Vizio E321VL - backlights but no OSD
  • ahickman
    • Jan 2012
    • 233
    Re: Vizio E321VL - backlights but no OSD
    No problem. This better?
      Great. Check here for 12V.
      • ahickman
        • Jan 2012
        • 233
        0 vdc
          That points to the main board not turning on the T-con power so obviously no video.
          Check all regulators on the main board -- standard Vizio procedure.
          Also any way you can test sound? Hook external source up and flick through inputs using input or source button.
          • ahickman
            • Jan 2012
            • 233
            U8 and U5 show no voltage on input, adjust and out. U4 shows voltage on all three pins.
              What are the voltages on U4? And the part #?
              • ahickman
                • Jan 2012
                • 233
                My mistake.....I didn't have power to the board. Showing the following voltages with respect to ground:
                U4
                VIn = 5.27
                VOut=3.30
                VAdj=2.05
                U5
                VIn = 3.34
                VOut=1.81
                VAdj=0.55
                U8
                VIn = 3.34
                VOut=1.25
                VAdj=0.00
                • ahickman
                  • Jan 2012
                  • 233
                  These are 1117 SMD regulators.
                    All regulators are fine. I am a little stumped now, I would suggest a microprocessor/firmware problem, though it could also be a bad power switch for the T-con power.
                    • ahickman
                      • Jan 2012
                      • 233
                      OK, thanks for you help. Confident that the problem lies on the MB?
                        With a Vizio that's about the only thing that seems to go wrong. I am 85-90% confident.
                        • ahickman
                          • Jan 2012
                          • 233
                          If it is a firmware issue, does that imply that I can flash the firmware or upgrade it? If so, suggestions on how to do it?
                            You can try contacting Vizio directly -- some people have had them send out a little box which plugs into the VGA port and flashes it that way.
                            • ahickman
                              • Jan 2012
                              • 233
                              Good night.
                              • ahickman
                                • Jan 2012
                                • 233
                                Re: Vizio E371VL - backlights but no OSD
                                Just realized that this set is an E371VL and not an E321VL.
                                • bpcannan
                                  VIZIO M557-G0: Backlights or ???
                                  by bpcannan
                                  'Morning,
                                  I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                  Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                  I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                  I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                  10-29-2023, 06:36 AM
                                • csmith
                                  Vizio-D50u-D1 Pulsating Backlights
                                  by csmith
                                  This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                                  Am I looking at a defective strip? Thanks in advance.
                                  11-07-2024, 02:56 PM
                                • x_orange90_x
                                  Replacing backlights in Vizio V755-J04
                                  by x_orange90_x
                                  I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                                  I have not replaced...
                                  12-03-2024, 07:03 AM
                                • Awsmessymail
                                  Vizio E701i-A3 backlight only and now no backlight
                                  by Awsmessymail
                                  Hello all,
                                  I’ve tried to repair TVs in the past with some luck. Toms repair manuals got taken down and now thats a bit harder.
                                  I picked this TV up hoping for a quick fix. When the TV would power on, only the backlights would come on. The owner told me they heard loud screeching before it shut off. This alone makes me want to think the main board has an issue.
                                  As I researched, I found the TCON/driver boards were an issue on this unit. I went in troubleshooting the TCON but found good voltages on the TCON. I followed shop jimmys guide to test the transistors and they seem okay....
                                  02-13-2024, 11:04 PM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
