42" Panasonic TX-P42C2E Plasma blinking fast green
  • nostrike
    • Mar 2012
    • 55
    • Denmark
    Hey all.
    I have a 42" Panasonic TX-P42C2E Plasma blinking fast green,
    and the screen is black/no picture.
    when I turn it on.
    I clicks, but power button flashes really fast something like 36-37 times
    and goes steady green. Nothing on the screen.
    The PSU is a :AASY NO LSEP1287
    The mainboard is a:TNPH0829
    I have tested the 4 fuses on PSU, they are all good.
    I have unplugged X og Y boards, but same problem.
    I will take pictures of the components as soon as possible.
    Anyone have an idea what could be wrong?
    Best Regards
    Nostrike
    Re: 42" Panasonic TX-P42C2E Plasma blinking fast green
    Does the set buzz while running?
    • tw2005
      • Oct 2011
      • 6458
      Flashing green then steady is normal startup. dead/cracked panel? If a board has failed it's unusual not to get a red blink code. Any audio?
      • nostrike
        • Mar 2012
        • 55
        • Denmark
        It does buzz while turned on from PSU (very quiet Buzz).
        No sound with DVD player
        There is a normal light in the Optical sound output on mainboard.
        When turned on, after 2-3 minutes the PSU clicks 3 times,
        After 2-3 minutes again it clicks 1 time og blinks red 13 times.
        Pictures :
        • nostrike
          • Mar 2012
          • 55
          • Denmark
          Found the Service Manuel.
          13 red blinks means Sound SOS - A-board Speaker
          So the A-board is defective ?
            I thought you said it was green not red?
            Check for shorted speaker cables. Wires touching frame for example.
            • nostrike
              • Mar 2012
              • 55
              • Denmark
              Wrote before :
              (Keeps blinking 13 times, pause, 13 times.
                OK, sorry, did not see that. Check the speaker connections then.
                • nostrike
                  • Mar 2012
                  • 55
                  • Denmark
                  I know my way around TVs,
                  but how to test Speaker connection?
                    Check the wires aren't broken or damaged, they are properly secured, and they have no connection/short to the chassis of the TV.
                    • nostrike
                      • Mar 2012
                      • 55
                      • Denmark
                      Have checked them.
                      Not broken.
                      Not touching chassis
                      Looks normal.
                        In which case I would suspect A board or DA board (depending on what this TV uses.)
                        • nostrike
                          • Mar 2012
                          • 55
                          • Denmark
                          A-board : TNPH0829 2A
                          My own conclusion was also the A-board
                          after testing, so I think you are right.
                          • livewire1
                            • Nov 2012
                            • uk
                            same issue here, well kind off.
                            got a TX-P42G10B which workS, but will sometimes not switch on. and just get flashing green LED.
                            have noticed a slight blowing of a cap on power board, going to replace that.
                            so did you get it working?
                            • nostrike
                              • Mar 2012
                              • 55
                              • Denmark
                              I am waiting for a new A-board.
                              I do not think we have the same problem.
                              I think your caps are bad.
                              When you replace them, it will work
                                Panasonic do not use poor capacitors, it would be extremely rare to see them fail. Some of the larger caps can look slightly bulged due to mechanical tension, but it is an illusion.
                                • livewire1
                                  • Nov 2012
                                  • uk
                                  replaced the cap.
                                  same problem.
                                  was able to look at it while it was in fault.
                                  209 volts ok.
                                  Led's on the SS and SC boards are lit.
                                  So according to the service manual it says it's the A or D board, as I do not have a D board guess it's the A.
                                  have managed to get an A board for £35 so will try that.
                                  • livewire1
                                    • Nov 2012
                                    • uk
                                    "A" board replaced.
                                    been working ok for 6 days now, so guess that was it.
                                      Great! Thanks for posting back the fix, too. It will help others.
                                      • karlpowell
                                        badcaps.net
                                        • Feb 2013
                                        • 104
                                        • uk
                                        sorry to jump this thread , can you let me know where you sourced the TNPH0829 A board from and how much ?
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                        • SevenOFF
                                          Denon AVR-X4000 – Fast red blinking after 2nd relay
                                          by SevenOFF
                                          I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
                                          According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
                                          Here’s what I’ve done so far:
                                          • Fully opened and cleaned the unit (a lot of dust inside)
                                          • Removed and visually inspected the AMP board → nothing visibly damaged or burned
                                          • Testing is done with
                                          06-18-2025, 09:54 PM
                                        • fixxy88
                                          Panasonic 55DX600u repair help - no display fast green then slow red led flash
                                          by fixxy88
                                          Hi everyone. I've been given a dead Pana 55DX600u that I hope to save from landfill. I suspect the tcon board or UC1 on that board.
                                          Set will flash green led and attempt to start, backlight gives a brief flash then set shuts down and red led flashes slowly. Voltages out of PSU look ok. TCon board gets 12v at fuse when attempting to start and 3.3v on L1 but main IC gets warm very quickly (heatsink/cover removed, felt with back of hand) during the second or two the 12v is applied before PSU shuts down. TVS diodes on lvds input lines are not shorted, no caps appear to be shorted. ...
                                          02-22-2023, 09:14 PM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
