LG 26LC55 -- Freezing, slow to boot up
    Thought I would post this as me and Sienoki dealing with it currently.
    Found that it would take 15 mins or so to start up sometimes, the screen would fade or have random lines on it.
    Found one cap on main board 100uF 16V, with 6.8 ohm ESR, for a 5V to 3.3V regulator. Regulator had 100mVp-p oscillation on the output. So cap will be replaced and we will try it out. Otherwise, I suspect t-con or BGA cracking.
  • kevinm34232
    • May 2012
    • 1884
    Re: LG 26LC55 -- Freezing, slow to boot up
    Tom I had a LG 26LG30-UA that did almost same thing. After about 15 mins picture would be normal but before that it would have half the screen or a frozen screen, different weird things. I played with freeze spray and a hair dryer and it seemed like it was the T-con board, but after replacing it, it did the same thing. Never fixed it, thought maybe bad VPU on main board..?
      Cap didn't fix it, it appears. The regulator may be at fault itself, or we may be chasing a wild goose...
      Regarding T-con I -think- it's the T-con due to it fading in slowly. That just doesn't happen with a main board. But repairability will depend on the T-con price. It has a Chi-Mei panel in it.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Does the EEPROM (if it has one) run off that 3.3v? It could be corrupt. I have seen corrupt EEPROM's make the screen fade and/or show random junk.
        Muh-soggy-knee
          Quite possibly, something to look at, thanks.
          • Rtech
            • Jul 2010
            • 1095
            Lo and behold,I have exactly the same...turns on and works well sometimes,other times rubbish on the screen,until it has been on a while, then bursts into life.
              It's a bad panel. I'll bet you've got a Chi-Mei LCD in yours. Anyway, it is the top left tab. It is fixable, but I don't know how long it will last. Encountered the same thing in a Panasonic LCD with a Chi-Mei panel.
              If you take the TV upright on its stand, and just carefully twist it left to right or right to left (flex the plastic case) and the picture comes right immediately, you know it's the tab bond issue.
              • Behemot
                • 4845
                • CZ
                I have the same TV with same problem - problematic start unitl it was only grey. I've disassembled the display and tried pushing the flex cables while in operation, no change. I do not think the problem is flex cables, but either something on the flex board, or something else.
                TCon seems to be somewhat working, I have also 26LC41 with blown fuse on TCon. I tried the 26LC41 with TCon from 26LC55 and it displays, however it is somewhat blue and otherwise strange.. But the TCons are slightly different, either it is that, or the 26LC55 TCon itself is bad. Will try swapping the displays as soon as I get the 26LC41 TCon working (need 2A SMD fuse).
                  • 12083
                  • U.S.
                  Very nice, fast accurate diagnosis Tom, that flex screen method can sure save a lot of time and money, from people wrongly throwing boards at it.
                  • Behemot
                    • 4845
                    • CZ
                    The TCon from 24LC41 burned another fuse, there must be some problem on it. The rail goes to several places incl. BGA chip Maxim 8728E which claims to be all-in-one multi-votlage output controller.
                    As it did not burn the other TCon boards fuse (though colors were bad, hopefully due to their difference), I think there is problem somewhere on this TCon. It makes sense the Maxim chip has burned to short internally. It is V260B1-C03, I can get repalcement ones for some 20 bucks so I think it is better than messing with this one…
                    • mamado mosa
                      Slow boot dell latitude 5410 laptop issues
                      by mamado mosa
                      So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
                      The problem is it takes more than a minute to boot ..
                      The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
                      Can someone suggest something to fix
                      06-19-2025, 06:55 AM
                    • privato89
                      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                      by privato89
                      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                      Let's begin:
                      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                      03-26-2024, 06:37 AM
                    • THXFX
                      samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                      by THXFX
                      Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                      I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                      When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                      What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                      I check capacitors and diodes and didn't find any short IN MAINBOARD.
                      Measured all power supply...
                      03-20-2024, 03:21 AM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                    • Stephen
                      A1990 MacBook Pro 15" Turning on, loads then boot loops, fan spin slow and then fast
                      by Stephen
                      Got a MacBook Pro 15" A1990 with a board issue, The board turns on, I did a DFU revive to see if it needed a firmware patch, that was successful, however the board just keeps boot looping and turning off and on very quickly. Obviously the DATA Is there, but it wont even launch into recovery, it will just die and turn back on with Apple logo, once it gets really hot it dies, if the laptop sits for the day and is cool, it will turn on then get hot within 1 min then die and turn itself on and repeat. Once it does that it turns itself on and off repeatedly in seconds. I put a thermal camera...
                      10-04-2024, 02:50 PM
