Self-Inflicted Damage: Vizio P50HDM
  • craigc15
    • 53
    Aloha!
    I am a TV guy from the 70's that obtained a EE degree. I've been involved in various pursuits, but now I'm back to fixing TV's!
    I worked on a plasma TV last year and decided I would avoid them, but I ended up working on a Vizio P50HDM. I'll skip the original problem for now. I need to get back there first.
    Problem: In my efforts to remedy the original problem, I was searching for "Bad Caps"! I replaced some of the big guys on the YSUS and ZSUS boards (the ones with slightly rippled tops), but that didn't change anything. I ended up removing/testing some of the caps on the PS board. Well, that's when the disaster struck. When I powered up the monitor (it's not a TV) all I had was what is shown in the attached picture.
    When I looked over the PS, I noticed I had accidentally inserted 3 caps in the "5Vctrl" circuit backwards. Amazingly they didn't blow! I replaced them with new caps, inserted properly, but the problem remains. (The "5Vctrl" voltage is fine).
    I have checked the following voltages:
    Va = 60V, Vs = 196V, -Vy = -200V, Vsc = 115V, Vsetup = 115V, Z_Bias = 95V
    I have also checked the IPM's according to this "Troubleshooting Manual": http://www.scribd.com/doc/16077007/L...07-VG-Training All is good, except a couple of the resistance readings were higher. I didn't think higher would cause a problem(?).
    I looked at the YSUS output waveform with my o-scope and it looks like a square wave. It doesn't look like the one shown in the manual.
    Then I created another problem. While re-installing the YSUS board I neglected to insert the screws that connect it to the Y-Buffer board! For those that don't know what happens when you do that, it arcs across the connections and wipes out Q1, R25, R26 on the YSUS board, and in my case it appears that it also wiped out something on the upper Y-Buffer board. The Vsc voltage dropped to about 85V with both Y-Buffer boards connected. When I disconnected both Y-Buffer boards, Vsc comes back close to 115V. I connect the lower Y-Buffer and Vsc is good, but when I connect the upper Y-Buffer, Vsc drops back down again.
    I checked the FETS and diodes on the Y-Buffer board w/diode mode on my DVM, and all check fine. I did a magnifying glass inspection of the driver chips, and I don't see any burnouts.
    Questions:
    1) Is there anything else I can check and potentially replace on the Y-Buffer board, or should I just buy another one on eBay?
    2) Any guidance on what might be causing what's shown in the picture? Maybe I clobbered both Y-Buffers by putting the caps in backwards?
    Mahalo nui loa!
    Craig
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Self-Inflicted Damage: Vizio P50HDM
    The picture on the screen is odd to say the least but I do t believe you will get an image unless you have a working upper buffer board.
    • craigc15
      • 53
      Thanks for the fast reply.
      The picture was taken before I (most recently) wiped out the upper Y-Buffer board.
        It is very typical for Y buffer failure.
        http://blog.coppelltvrepair.com/2010...er-boards.html
        http://blog.coppelltvrepair.com/2010...-lines-in.html
        • craigc15
          • 53
          I am familiar with that info. I communicated with Bobby (Coppell) last week.
          I have taken the measurements he suggests and everything checks fine, but given that having the Upper Y-Buffer connected loads down the Vsc, that's a strong indication that it's at least one of the driver chips.
          Sounds like it's time to buy some Y-Buffer boards.
          Any other suggestions welcome!
          Mahalo!
          • craigc15
            • 53
            I forgot to mention one more piece of info.
            When I press the "Input" button, the vertical line strip widens and shifts to the left edge of the screen (where the input info normally appears).
            Does this still sound like a Y-buffer problem?
            Mahalo!
            • freakaftr8
              • Oct 2012
              • 3743
              That's a ysus problem.
              • SS454
                vizio e650i-a2 backlight flashes then turns off
                by SS454
                vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                panel: au optronics T650HVN05.4
                72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                https://www.shopjimmy.com/vizio-56-0...-power-supply/
                Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                08-20-2020, 03:57 PM
              • mrtek
                Vizio M65-C1
                by mrtek
                Hi.
                picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                07-14-2025, 07:28 PM
              • howardc64
                Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                by howardc64
                Failure Symptom
                No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                Where is the short?
                Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                05-27-2025, 02:56 PM
              • howardc64
                Vizio SmartCast TV software bug that looks like hardware
                by howardc64
                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                11-16-2024, 05:17 PM
