Panasonic Plasma 42" TH-42PV60H - Black Vertical Band
  • spintop
    • Feb 2011
    • 132
    Hi
    I have a Panasonic Plasma 42" TH-42PV60H with a black vertical band in the middle of the screen (see attached). I opened up the tv to reach the C1, C2 boards and do some cleaning and re-sit the flex cables but did not resolve the problem.
    Could it be the bond tab issue here i am facing, i read that Pana screen tab cables have these issues and not replaceable.
    Please advice thanks everyone !
  • rayrod81
    • Oct 2010
    • 205
    Re: Panasonic Plasma 42" TH-42PV60H - Black Vertical Band
    It is possible that the C1 Buffer has a failed buffer IC that is causing the problem.
    This plasma is old enough that the Buffers were built with the buffer ICs on the board and not on the ribbon. I have seen this on both some Panny's and LGs of this build and more times than not it is the C buffers and not the panel itself.
    The beauty of it is that the C1 buffer can be found for less than $30 and if the problem still persists then you can part out the TV and get more than your money back.
    • spintop
      • Feb 2011
      • 132
      Indeed, there are some C1 buffer boards available online which i can buy, not too expensive. i also found out online that many also have this problem and unfortunately the fault lies in the ribbon. I have decided to give local panasonic centre a call and see they can offer a cheap solution though this one is out of warranty. And someone got it replaced FOC, as its a common problem with pana plasma. Otherwise the last option is to buy a board and try my luck.
      • evanroheff21
        Panasonic TC-P65ST50 plasma vertical black section repairable?
        by evanroheff21
        I've acquired a 65" Panasonic TC-P65ST50 for free from someone while purchasing another TV for repair from them. I've repaired ~10 LCD TVs over the years with decent success, and I enjoy doing it. However this is my first attempt at a plasma, and I'm treading carefully.
        The TV when I got it would power up, however the left ~5 inches of the display was entirely black, basically like a letterbox image would appear. I disassembled, looked up some info, and determined that it was likely either dirty/loose connectors between the panel and the C buffer boards...
        03-10-2020, 10:15 PM
      • Stasonio
        Panasonic TX-PR65VT60 plasma flickering pixels on black
        by Stasonio
        Hello!
        On my Panasonic TX-PR65VT60 plasma, flickering pixels (or subpixels) run uniformly on completely black areas of the image or on a completely black screen (for example, an image with completely black areas, black fill, or hdmi, AV input without a signal). This can be clearly seen in complete darkness at close range, and is very similar to how it is shown in these videos:
        https://youtu.be/IgcqC12Wc2U
        https://youtu.be/Bfzaw4D2Byg
        I repeat that this happens only in completely black areas, otherwise there are no complaints about the image and the operation...
        05-14-2020, 08:20 AM
      • Nirrain
        Panasonic TX-P42S20E Plasma tv. First purple sparkles, now completely black
        by Nirrain
        I have a Panasonic TX-P42S20E plasma TV that lately has been showing flashing pink pixels when the picture is bright (similar to picture 5 in this post), primarily on the top half but to a lesser degree in the buttom half.
        I've tried to change VSUS to high but it made the issue even worse so changed it back.
        However, this is all a backstory as yesterday after being on for about 5 minutes the screen turned black. I've tried to hard reset (hold power on tv for 30 sec).
        When turned on the green LED flashes 6 times and then stays on continously....
        07-09-2021, 02:38 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • Firentiosi
        1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
        by Firentiosi
        Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
        The issues are as follows: the...
        11-27-2024, 12:33 AM
