LG 50PC1DRA 50" Plasma
Was not powering on. Pulled power supply and found 12-15 caps that were bulged. Replaced all in question and now TV turns on. Problem is that something else is obviously wrong.
When I first power it on, only right side edge had a picture. Rest of the screen was black. Had no signal going to TV so it was just your standard fuzzy picture. I noticed right away that the picture was growing. The fuzzy static was spreading slowly, eventually filling up most of the screen.
While the screen was slowly filling up, I got the menu to pop up but it was hard to read. Almost as if the the colors were messed up.
I have attached a few pictures. I apologize in advance for the poor quality and viewing angles. I did not receive the TV with stand so it is kind of hard to take a picture while holding it. The pictures still show a black splotchy area that had not filled in. I shut it off before that area had filled in. I am not sure if the display will fill all the way up. Also note there is a dark square that can be seen.
Please note that I shut the tv on and off a few times and the screen seemed to stay lit where it had been. I have not turned it on for about an hour or so. Will go see if the screen has reverted back to mostly black. Will try and get some more pictures too.
Thoughts on the issue? I am not familiar with plasma tv's so dont quite understand how they work. Mostly dealt with LCDs and even at that, its been power supplies and inverters. Thanks!
