Sharp lc-52e77un Blinking light
  • Ricerider
    • Oct 2012
    Hi all new here, have a shap aquos Model # lc-52e77un
    when plugged in the green power led comes on and i get a relay click but no picture or sound, ~10secs later i get a another click and this repeats multiple times before settling at power and opc led blink once together, then power led blinks twice and repeat. No picture or sound
    Opened back of tv and found top inveter not seated properly, pushed inverter back into place. Powered up no change. Also tried holding input and volume down when plugging in, no change. Would like help testing ouput voltage of power supply or whatever needs to be done. I have a multimeter, solder gun and smd rework station.
    Any help greatly appreciated, this is a 52" so its hard to just scrap it
    Re: Sharp lc-52e77un Blinking light
    Count the blinks on the power LED and OPC LED.
    For example 5 blinks power, 2 blinks OPC, or 5-2. That is backlight failure from memory. (Don't quote me.) The service manual will tell you what the code means.
    • Ricerider
      • Oct 2012
      power and opc led blink once together, then power led blinks twice. Repeats same blink code over and over.
        OK 3-1 blink code then
        Service manual is here: http://www.tgohome.com/ServiceManual...&Search=Submit
        The first manual is the document for the LC-52SB57. The second contains the changes between that and LC-52E77.
        Error codes are on 6-15.
        3-1 error: "Initial communication from the main CPU is not received. (Request for the monitor model No. is not received after canceling the reset.) → Communication line error or main CPU start-up failure."
        • jkomorek
          • 37
          I am looking at a TV with the same 'blink code'. Did you ever get resolution to this, and would you mind sharing?
          • rawan
            • Oct 2009
            • 57
            Hi
            Any luck with this tv?? I have same problem, same model.
            LED Blinks 3-1 times.
            Any help please.
            Mac
            • Sevenqi
              • Jul 2011
              • 292
              Hi any one know the solution for this 3-1 error code for Sharp ? is it the mother board problem ?
              • cashkennedy
                • Aug 2011
                • 666
                Id assume "main cpu" means the processor on the main board. So after confirming that all the voltages are reaching the mainboard appropriately (whether that be 3.3v, 5v, 12v, so on) then I would say to replace the main board.
                Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                • Sevenqi
                  • Jul 2011
                  • 292
                  I had the same error code with the same model, after replaced the main board, tv works perfect.
                  • mbates14
                    • May 2005
                    • 169
                    This seems to be a very common problem, and is happening in droves lately. over various different models.
                    I am starting to wonder if the main CPU's SPI flash memory isnt getting corrupt, and therefore it cant boot.
                    • icestation
                      • Nov 2023
                      Nope, the FLASH is just fine:
                      I moved the FLASH, the 64K EEPROM, and the 2K EEPROM (contains the monitor size) over to another main board and that main board booted properly. (Original main board was DKEYMF953FM05 new main board was DKEYMF953FM06, so yes, the Monitor CPU ROM OTP contents were not identical, but new Monitor CPU still worked with the previous 2k EEPROM) Target TV: LC-80LE844U, now working.
                      • Fergal22
                        Samsung UE40F5300AK blinking red light
                        by Fergal22
                        I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                        When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                        I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                        Any help would be appreciated...
                        02-02-2023, 09:19 AM
                      • mecha1166
                        XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                        by mecha1166
                        I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                        07-01-2024, 05:47 PM
                      • norbiszoke
                        Samsung 50AU7172, only blinking red light
                        by norbiszoke
                        We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                        Regards, Norbert!...
                        04-17-2024, 06:54 AM
                      • matty24
                        Samsung UE50MU6172 - red light blinking
                        by matty24
                        Hello. I have problem with Samsung UE50MU6172.
                        TV won't turn on, red standby light is blinking.
                        Power supply BN44-00807A is fine. I replaced it with the new one.​
                        Main board BN41-02568B (BN94-12530E)
                        I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                        03-02-2025, 08:57 AM
                      • 1centchips
                        Asus rog strix g1614jv-Is96 freezes at random times and blinking charging light
                        by 1centchips
                        I have the i9 version. I have tried disabling intel and Nvidia graphics in the device manager.
                        The laptop is just out of warranty.
                        The laptop continues to freeze randomly with the blinking amber charging light.
                        What could be possibly wrong with it?
                        I have also disable armoury crate in bios.
                        12-17-2024, 05:18 PM
