Bush IDLCD32TV16HD Dead
  • gilly1984
    • Jun 2012
    • 751
    Re: Bush IDLCD32TV16HD Dead
    Thats what i thought, gave it a few taps but it stays on. Anyway, fingers crossed.
    I'll test for a week then sell if all is ok.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • gilly1984
      • Jun 2012
      • 751
      Right, another problem.
      VGA Input says no signal? Tried 2 different vga cables to no avail.
      tv works fine on hdmi, built in freeview works fine.
      Any ideas?
        What resolution are you using?
        It's unlikely to support anything more than 1366x768.
        • gilly1984
          • Jun 2012
          • 751
          On the screen i am using it says my bios splash screen is 480x800, then windows loading screen is 800x600 then once windows has loaded its 1360x768?
          So i should at least be able to see my bios splash but i get nothing, the tv just goes to sleep because of no signal.
          Very strange.
          Just searching for a firmware update now OTA through the tv menu.
          Doubt there will be one though.
          If none i will do a factory reset, but after that if it still wont work then i have no idea.
            I think you might just have to use HDMI.
            • gilly1984
              • Jun 2012
              • 751
              No good for resale though as i dont plan on keeping it.
                How many people use VGA though? A great deal of people just watch TV. You can note that the VGA does not work.
                • gilly1984
                  • Jun 2012
                  • 751
                  True. I just like to sell things in full working order to make myself feel better.
                  I'll try the reset, then try 2 monitors on my pc, can mess with res settings then.
                  • Kingspin
                    Technician.
                    • Aug 2012
                    • uk
                    #49
                    I know this fault has nothing to do with the fault mentioned here but
                    if you get an IPOS 150 power supply for repair that is dead with just a faint ticking noise heard
                    always check D10 for short circuit this is a known common fault.
                    TV Technician & Lifetime Electronics Student.
                    BTEC,C&G 3.
                    • gilly1984
                      • Jun 2012
                      • 751
                      Thanks Kingspin, i got another ipos 150 from ebay, last one went in the bin after i shorted the bridge rectifier and god knows what else.
                      • PsiDOC
                        BUSH 42" LED TV. BLED42FHDAE Completely dead. Diagnosed and solution awaiting parts..
                        by PsiDOC
                        HI all. Just a note for anyone that has one of these TVs.
                        Make: Bush (China)
                        Model: BLED42FHDAE.
                        Symptoms: Half screen went dark, then tv wend dead. No power lights. Fuse checked ok.
                        First thing checked was standby 5v: Present @ 5.1v.
                        PS_ON signal from main board: Present @ 4.5v.
                        I suspected the power supply to be in a foldback / crowbar condition after the screen going out, so I disconnected the power to LED Backlight board (Part ER643). Now standby light is on and TV responds to remote power on - light goes green.
                        Disconnected the LEDs from the...
                        10-30-2021, 05:22 AM
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • disorder
                        ps5 edm-033 dead after hdmi/usb ports destroyed
                        by disorder
                        hello guys,
                        i need help to repair a edm-033 ps2
                        history : as always hdmi port and usb ports destroyed after unplugged
                        after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                        so i changed it
                        now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                        but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                        i don't see any projection of liquid metal on pcb.
                        01-14-2025, 12:48 PM
                      • zunasthegreat
                        Chieftec GPS-450-AA with dead 20N60C3
                        by zunasthegreat
                        Hello everyone hope all doing well!
                        I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                        09-01-2024, 07:12 PM
                      • Beton
                        Finding a dead short component
                        by Beton
                        Hi guys!
                        I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                        So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                        I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                        I have a bench PSU and if I try to inject voltage the voltage...
                        12-10-2021, 01:05 PM
