Re: sharp lc-c5255u only blink codes no picture
I have this same model TV, a Sharp LC-C5255U. A lady in the neighborhood was giving it away for free to anybody that wanted to see if they could fix it so I grabbed it. Steady 1 Hz flashing green light. I can do the Channel Down and VOL + and turn on the TV or plug in the TV and I get the screen to light up for about 1 second before going dark again. No clicking or anything. I'm wondering if it is just a bad PSU. The other option I was able to track down was it may be a bad LED display, but since the screen lights up (in some manner) I'm wondering if that means it is OK, or since it is just a quick on/off, if the LED display is bad? Any ideas?
i tried channel down +vol up, the led remained steadily green but black screenLeave a comment:
i have a sharp lc-52d78un with power leds blinking. so am stock any help will be greatly appreciatedLeave a comment:
I had the same issue (2-5 error) and I did the "Channel Down & Volume Up," reset and now my light no longer flashes. It just stays on and it doesn't appear that the backlight is coming on. Any thoughts or ideas before I crack this baby open and start disconnecting ribbon cables?Leave a comment:
Also when the PSU comes on you get a relay click. When I turn the unit off I get a louder relay click.Leave a comment:
I am new here and have the same TV as mentioned. Mine gives no error codes and only has a solid green led when the power button is pressed. Just a black screen. Tried the force power on with same result. Any ideas.Leave a comment:
I just repaired this LCD tv exact same model.
symptoms- when the tv turns on, all I get is a black screen with blinking green light. No other error codes. It was crazy frustrating trouble shooting this. I measured the transformers on the master and slave inverter board with a multi meter. The resistance should be 1.31 k ohms. All but one measured within the specs except one. I get an OL reading. Note I did my measurement with the tv powered off. I set my multi meter on the ohms scale. I took a chance to order this part on eBay for 13 dollars. After soldering it, the resistance for all of the transformers were back to specs. The tv powered on and stayed on. Works good as new. If anyone has the this similar issue I would advice testing the mini transformers on your master and slave inverter board. My email is normanw1@yahoo.com for help.
lcc5255u aquos fixed
lcc5255u aquos resolved
Note, it was very very very challenging troubleshooting this problem because I didn't get any other error codes except the blinking green light. There wer no visual signs of bulging capacitors, or melted resistors. I read so many things on the main board, power supply board, cfls and inverters could go bad. Also with this tv if there are any problems with any parts of the components , the tv goes into standby mode.Leave a comment:
Thanks for the input and info. Gotta decide what to do with the unit now..2 power, 5 opc led blink code is an error in the 12 volt panel power. A broken and shorted screen is a frequent cause of this error. If the LCD screen is OK, it can be a short on the t-con board as well. In this case, the rest of the boards are likely to be OK.
(2 long, 5 short also means the same thing)
(2 long, 5 short also means the same thing)Leave a comment:
Yes those are configuration jumpers. Inserting the jumper opens up a set of contacts.Leave a comment:
It could simply be because the LCD is so damaged you can't see anything, try the input button and see if you can get a video from an external source (like a DVD player.)Leave a comment:
I always thought you could tell if the screen was smashed?
If not by naked eye then by torch or camera flash.?
I was so happy when my recent collection showed a screen, thought i had been done too.Leave a comment:
That thing looks to be have been hit, not dropped. Probably another Wii controller!
Can you get a menu or interface up on the LCD at all?Leave a comment:
Oh, just have to post a shot of the screen after I followed your advice...pretty colors!Leave a comment:
You get bitten by some people selling broken TVs, though I've only been ripped off once by someone who knew the screen was cracked (he pulled a fuse out on the power supply so it didn't light up.)Leave a comment:
I'll ask my son to talk with neighbor and find out (they live 200 miles away from me). Guess I will have to find someone who needs some parts for their sharp TV now...oh, well..live and learnLeave a comment:
No solid idea myself - perhaps option jumpers or settings for models?
Did you ask the neighbour what happened when it failed?
Maybe it fell and this broke a CCFL tube, hence the error code and cracked screen?Leave a comment:
Thanks for all of your assistance. I needed to know if the LCD screen was damaged anyway before investing anymore time/money into this project. I really appreciate your quick replies and help. Do you have any idea about the fuse like parts in the picture? Just curious....Leave a comment:
Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
Regards,... -
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by BeeShadowHey everyone! I inherited a "free" Sharp lc-70le755u with a strange picture issue. To try to explain, the picture flickers before what I think is a power saving mode kicks in and reduces the back light. I took a short video and uploaded it here:
https://imgur.com/NAou7aP
I'm thinking it could be the TCon board, but possibly the panel. Thought it might be worth it to post here and see if anyone has a better idea before I try throwing parts at it. If its the panel (which I hope its not), then I won't bother trying to fix it. - Loading...
