SHARP LC32AD5-GY wont turn on
  • rdb89
    • Jan 2012
    • 10
    Hi, today my SHARP LC32AD5-GY is totally dead. Yesterday the tv was working fine, today i turn it on but i only have the green light when i press the power button. I have no picture and no sound and the tv is stuck on black screen w/o light. If i press the power button the tv doesn't turn off, the only way to turn off is to remove the power cable. There is any way to fix it? Anybody had the same problem?
    master hoarder
    • May 2008
    • 12175
    Re: SHARP LC32AD5-GY wont turn on
    Probably best to take it apart first and looked for obviously bad components. Posting pictures on the forum of the insides of your TV would also help a lot with the troubleshooting.
    Lastly, do you have a multimeter or can you borrow one? And if yes, do you know the basics of how to use it?
    • thetonywarren
      Sharp 4P-B43EJ2U wont turn on
      by thetonywarren
      Sharp TV/Display, wont turn on. Brand new, used for maybe 30 minutes. Possibly heard pop then set went dead. I took a look at the boards, no visual damage to boards. The led power indicator is ON, remote will not turn on. I verified that backlights do come on when powered with separate power supply/LED tester. I also...
      10-01-2025, 09:30 AM
    • Adogabriel100
      Macbook pro A1278 820-2936 No light/turn on
      by Adogabriel100
      Hey! how are you guys? i wonder if you could help me with this macbook 820-2936 that does not turn on. (Doesn't have green/orange light).
      History:
      this macbook came for a short on C6990 that blows D6990 and R6990 on his way. i re-placed the componets and it work again.
      A month later comes back again and has the actual problem (no green/orange light and dont turn on)
      The macbook can turn on with only the battery connected but in fact, dosent charge.
      Voltajes:
      PP3V42_G3H = 3.3v
      PPBUS_G3H = 12.2V
      PM_PWRBTN_L...
      06-28-2023, 07:41 PM
    • Woodsworth
      PS3 CECHC03 60GB YLOD Troubleshooting
      by Woodsworth
      I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
      START
      Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
      03-19-2024, 07:58 AM
    • dionzarek
      PS5 Slim EDM-040 Only turn on 1 Sec, Blue light then immediate off.
      by dionzarek
      Hello everyone, I am new to this PS5 troubleshooting, I need help on diagnosing the problem. My PS5 Slim board EDM-040 that beep and only shows blue light then immediately turn off.
      I've checked the PSU its normal 12V. I've checked all the capacitors its all good no shorts, but there are 2 caps shorted, I think its near the SSD. You can look at the image attachment.
      When tested it only shows 0.003 while other caps show 0.4 to 1. WHen in continuity mode those 2 caps goes beep/shorted.
      Any help to where should I check on or suggestion would be very appreciated....
      02-08-2025, 11:00 PM
    • vdrokko99
      MBP wont turn on Only green light on charger
      by vdrokko99
      I have a similar problem... I got an old MBP for free, but wont turn on... Only green light on charger. I measured these voltages. If i try to do an smc reset using keyboard, nothings happen, wont go out the green led. I dont know how to continue, please help me.
      SMBUS_SMC_BSA_SCL 3.5V
      SMBUS_SMC_BSA_SDA 3.5V
      12-01-2024, 12:18 PM
