Vizio VW37L HDTV20A Power supply No Standby Voltage
    Re: Vizio VW37L HDTV20A Power supply No Standby Voltage
    So with the bridge rectifier removed, the short is no loger there then on the output side of the rectifier.
    And if you measure the two pad where the rectifier AC (~) INPUTS are, do you get short circuit?
    • Worminizer
      Telephone Guy
      • Aug 2012
      • 51
      The short goes away on the non feed side after the bridge rectifier is pulled. It remains, until the inductor is pulled. After that its all ok, so there are at least two troubles in components.
        Burnt out line filter is really rare, it must have had a lot of current flowing through them, I would expect the fuse to blow before they shorted out like that, the filter can be removed and bypassed for testing other function of the board.
        • Worminizer
          Telephone Guy
          • Aug 2012
          • 51
          oh, good, I'll get a new rectifier and see if I can get it back to life then. I have a few power supplies laying around. I will see if there are any rectifiers I can scavenge.
          • Worminizer
            Telephone Guy
            • Aug 2012
            • 51
            by the way, I took a good portion of the shock myself. I'm pretty used to getting hit at work by leaning my arm against an array of T-1's, Ringing generators, and power feeds, Stupid I know, but its a good reminder to be careful, because there are more hazardous voltages than just 120vac in a tv set.
              I would plug the TV into a GFI outlets for safety and also use an Isolation transformer as well.
              http://s807.photobucket.com/albums/y...t=DSC00073.jpg
              • Worminizer
                Telephone Guy
                • Aug 2012
                • 51
                I will be doing just that.
                • Worminizer
                  Telephone Guy
                  • Aug 2012
                  • 51
                  Could you help me distinguish which bridge rectifier I should order from digikey? I have looked, and there are over 2000 to choose from. I am just not that familiar with the devices to know the difference. Here is the datasheet, it is an 8k.
                  http://pdf1.alldatasheet.com/datashe.../US8KB80R.html
                    It is 800V 8AMPS D6K package.
                    You can get it from here:
                    http://www.bdent.com/US8KB80R-7000-p/us8kb80r-7000.htm
                    I did not find the same D6K package style at DIGIKEY.
                    Or the higher current rating one with the same case size:
                    http://www.bdent.com/US15KB80R-7000-...kb80r-7000.htm
                    • Worminizer
                      Telephone Guy
                      • Aug 2012
                      • 51
                      thanks bud
                      • Worminizer
                        Telephone Guy
                        • Aug 2012
                        • 51
                        Ok, I got my bridge rectifiers in, I threw one in, and remade my own inductor. I re-wrapped the magnet with new wire, and actually made it new again. Everything is back to where I was before I oopsed. I also changed out both of those capacitors with new low esr ones, though neither one tested faulty with either a capacitance tester on the fluke, or the esr meter. I still get 0v on the 5v rail. What would I check/replace next? Should I order a new controller IC?
                        • Worminizer
                          Telephone Guy
                          • Aug 2012
                          • 51
                          Ok, I reread the whole thread, since its been a while, and I looked at what retiredcaps had said,
                          2) A fluctuating voltage suggests one of the following
                          a) the startup cap, c213, is bad (the small ones rarely bloat)
                          b) the SMPS IC is bad
                          c) there is something shorted on the secondary output side (like a diode)
                          3) The SMPS IC needs stable DC voltage in order to work properly.
                          I began looking at the diodes on the board, and found one that isn't shorted, but it's wide open, and visibly has a chunk blown out of it. I will attach a photo. I can still see from what is left that it is an A2 in location D207. I will try to salvage one from something else and see if it fixes my problem. I'm not sure what the value is though...
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            I don't have any experience in deciphering these smd 2 letter codes, but this
                            http://www.s-manuals.com/smd/a2
                            leads to
                            which leads to my guess as it being UDZS 5.1B A2.
                            --- begin sig file ---
                            --- end sig file ---
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • fharris1977
                              Vizio D50u-D1 Dead Set No Standby
                              by fharris1977
                              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                              12-28-2023, 10:25 AM
                            • Yanleb
                              UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
                              by Yanleb
                              My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
                              Disconnecting the main board from the power supply makes the backlight come ON.
                              I did disconnect the panel cables and the WIFI modules, the board is still dead.
                              I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
                              Thanks.
                              11-18-2024, 12:34 AM
                            • reessi
                              JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                              by reessi
                              I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                              You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                              Years ago it had some bulging caps...
                              04-26-2021, 11:42 AM
