Toshiba Picture Fades To Black But Audio Continues
  • hairyturtle
    • Oct 2012
    Toshiba 42HL167 . Picture fades to black after a few seconds. It use to be after a few hours, then after a few minutes but now after seconds. I bought and replaced PS board, then Input board, then Low B board. The only board left is the 'Seine/Input' board. I guess I'll try that one too but am very frustrated and don't think this will work either. Here's a short video I uploaded that shows the problem:
    http://www.youtube.com/watch?v=q06jYJ2nbXs&feature=plcp
    Any ideas would be welcome. I'm no expert on electronics (internal combustion engines are my game)!
  • Hobby 1
    • Mar 2010
    • 86
    Re: Toshiba Picture Fades To Black But Audio Continues
    I can't tell from the video if the backlight is still on. Is it? If it is, then I would suspect the tcon board. Looks like somthing overheats quickly and kills the video.
      It's hard to tell but it looks like the video freezes and then it fades out in bars - this points to T-con as Hobby 1 suggested, or possibly panel...
      • hairyturtle
        • Oct 2012
        Thank you for your inputs. Two followup questions:
        Where is this Tcon Board located. I don't see that on the rear side of the tv. Is it behind the panel/screen?
        Also, when you inquire about whether the screen remains 'backlighted', what do you mean by this? Are you asking if the picture screen reverts to its black 'off' condition vs. backlighted which would show some sign of a grayish, lighted screen?
          T-con is at the top of the screen (sometimes at the bottom on newer sets) and connects to the LCD panel itself and the main board. It's not the power supply, which connects to the mains power, or the main board, which has video inputs on it.
          • Hobby 1
            • Mar 2010
            • 86
            Backlighted means the lamps are on and you can see bright lights in the back of the screen through the little holes. If the lamps are on and all you see on the screen is a grayish lighted screen, it is a bad tcon board. Get the part number off your board and start looking on ebay. Get the exact same one. Match the ebay pic with yours. The same model set can have several screens used during production.
            • RON_CET
              • Jun 2012
              • 217
              Here's some things might help with your troubleshooting, hope this helps
              Ron Driver,BSEE,CET,ISCET,NESDA
              • tibimakai
                • Jan 2012
                • 3680
                Did you managed to get to the bottom of this issue?
                I have the same TV with a very similar issue. I can't see those vertical lines on mine though and the black spreads from the center outwards (as if you would pour a black fluid on the center of the screen and it spreads outwards).
                The TV runs for good while until this issue comes up.
                I know that I should check the T-con, that is why I'm asking before I take the whole TV apart, I don't even see where the T-con is located.
                • Techstar
                  Tv Restoration
                  • Dec 2012
                  • 122
                  • United Kingdom.
                  You will probably need to take all of the boards out and do a lot of dismantling to get access to it. Be carefull when unplugging it's connector
                  it's easy to bust these connectors to the tcon board , when fitting or handling the
                  new one use anti static wrist band. I have not done one on this particular
                  tv so i don't know the finer details of how to get to it.
                    You can try heating t-con with a hairdryer to see if issue occurs immediately. When something gets hot in this TV, it malfunctions.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have taken this TV apart and did some measurements.
                      Most of the voltages are fine, but two of them are much higher compared to there markings.
                      There is a voltage of 40V marked and I'm measuring over 48V and the second voltage is marked 18V and it's alnost 21V.
                      One of the double diodes (D870) in the secondary installed on a heatsink with other two double diodes it's getting pretty hot, 66 C. If I have read the schematics correctly, that is the inverer 24V power supply.
                      The inverter seems OK even after the back screen shows up. Backlight stays on, sound is still on.
                      Capacitors are Nichicon, none of them seems bad, but I will check them anyway.
                      Any input would be appreciated.
                        I've worked on the 32WLT66 and saw a high 48V on 40V, but my 18V was dead 18.2V. Still, the 18V only powers standby regulators, and it's regulated down to lots of different voltages across the boards.
                        If it exhibits the same symptom, you can clearly see the backlights are on, so it is not a backlight issue, it is t-con, or power to the t-con, or panel.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          These are the voltages that I'm getting:
                          Inverter connectors are getting exactly 24V
                          main PS connector:
                          18V= 20.89V
                          40V= 48.05V
                          Aud Vcc= 30.32V
                          Pow Sig= 3.28V
                          5V1= 4.9V
                          secondary small PS connector:
                          24V inv=24.2V
                          6V= 6.39V
                          12V= 11.80V
                          CV61 connector from main board to T-con:
                          4.87V
                          3.09V
                          3.39V
                          0V
                          If I pull this CN61 plug or the LVDS cable from the mainboard the backlight goes off too, that is normal?
                            Can be normal on some sets if t-con controls backlights - for dynamic dimming. I'd try freeze spraying t-con to see if you can wake it up again.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I don't have a freeze spray. Can I use a air spray upside down? The problem is that some fluid comes out and I'm afraid to spray that to live boards.
                              I have sprayed to the panel, but nothing has changed.
                              • randtek
                                • Oct 2011
                                • 280
                                • US
                                That liquid is electronically inert. You can safely use it on live electronics. I do it often. Even using it until the board frosts up is fine.
                                  I thought that. And indeed, it is -- up to a certain point. I was spraying a power MOSFET in a PFC section with the stuff when BANG... everything tripped. Luckily, the PSU survived with no damage, it just tripped the breaker. So I don't know if I was using cheap stuff or was just unlucky.
                                  • randtek
                                    • Oct 2011
                                    • 280
                                    • US
                                    Good to know. Use with some care in high voltage areas. Thanks Tom.
                                    • randtek
                                      • Oct 2011
                                      • 280
                                      • US
                                      OT - I once saw a guy spray "Flux-Off" on the HV anode of a CRT set. It resulted in about a 1 1/2 foot (1/2 meter) fireball flash right in front of his face. Didn't hurt him, can't say the same for his underwear!
                                        Also OT: I built a little breadboard project using the flyback transformer from a plasma ball. I was able to generate up to 30kV arcs from 20V in, quite impressive, though they only tingled. I accidentally spilt some water on the oscillator, so immediately grabbed my compressed air can to clean the board. I'm sure you can understand that propellant around an arc is not, in general, a very good idea. Nice fireball! but amazingly, no damage to the circuit, or to my eyebrows that day.
                                        • kerberos137
                                          Sony xbr-65x930e faded to black; now has backlight but no picture
                                          by kerberos137
                                          Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
                                          11-29-2022, 05:40 AM
                                          09-06-2024, 05:59 AM
                                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:33 AM
                                          Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
