Faulty Samsung PSU (BN44-00427A) PD46B2_BSM
  • Mr_K
    • 111
    Re: Faulty Samsung PSU (BN44-00427A) PD46B2_BSM
    The original one tested shorted out. Now there is a short on the circuit board when 2 NEW FETs are installed. With only one installed, the circuit is fine.....
    • Mr_K
      • 111
      Update: If i instell one FET in one of the places (doesn´t matter wich one) the TV runs fine. As soon as two FETs are installed it´ll will blow the fuse and the short is back.
      UPDATE2: Problem found ;-) I made a stupid mistake..... The FETs are not isolated from the heatsink. Something I didn´t think of......
      So BIG THAKS to tom66. You saved me a lot of money!!
      BTW: The PSU is kind of noisy. Not a big deal..... I think its the big coil in the middle of the board. Do you have a unit to compare? Is this normal?
        Never repaired an LED TV - but would like to.
        Will keep an eye out for this model - typical Samsung bad design leading to failed FETs.
        Glad you fixed it.
        • Milan78
          • Apr 2014
          • Malaysia
          Hi, I got a faulty Samsung PSU (BN44-00427A) PD46B2_BSM, when turn on clicking appear but no display, can anybody help?
          • rbrash1287
            • May 2014
            I also have a similar issue with my Samsung UN46D7000 with PSU BN44-00427A which I have located the problem on the board itself visually. I am pretty knowledgeable with electronics but have only worked on PC's(troubleshooting, hardware/software issues, PSU's, motherboards, etc) but this is new territory for me with this TV. I simply need advice to be pointed in right direction from here as to what parts I should order to try repairing myself. I specifically need help identifying the burned out parts that I should order.
            These pictures identify the burned out transistor on my board and where it's located. I believe the transistor is QQ855 in that block where you notice the copper showing. I have not checked any voltages, currents, etc yet. If there is something you notice from this problem that I should check, I am all ears. Thanks.
            • Cryogen
              • Jan 2015
              • 91
              • United Kingdom
              #26
              Can anyone tell me which are the voltages on this power supply? I cannot find any schematics for this model.
              My Samsung switches on but no sounds or picture , just the backlight is present. The led standby light flashes 5 times.
              • Morten_dusk
                • Mar 2015
                • Denmark
                #27
                Does anyone have the schematics for this board?
                My TV is flickering and I have found a shorted rectifier diode (D9601) and possibly a near shorted resistor (R9601), but I cannot read its intended value.
                The diode and resistor are next to each other on the top left hand corner in the attached photo.
                My TV is a Samsung UE46D5767WK
                https://www.badcaps.net/forum/attach...5&d=1401408578
                • thoma
                  • Sep 2012
                  • 268
                  Isn t it possible to get schematics from Samsung newer SMPS?
                  Is there nobody who can look into gspn samsungscportal.com?!
                  I want to know if there are the schematics of BN44-4..
                  BN44-5.. and BN44-6.. SMPS.I can t believe that there are no schematics of the newer SMPS!Who is the supplier of the new SMPS from Samsung?
                  We can carry all these informations together perhaps we can solve the problem!
                  many regards thoma!!
                  • Louis82
                    • Feb 2012
                    • 240
                    Guys,
                    Working on same board BN44-00427A. Found QM803 Fet and FP803S Fuse to bad. Replaced them and now i get voltage but they are fluctuating. Stb goes from 0.6 to 5v on CNM803 connector. Also, big filter cap voltage fluctuates between 380v to 396v.
                    Any idea what i could check?
                    • cikgu
                      • Dec 2018
                      • Malaysia
                      #30
                      Originally posted by Louis82
                      Guys,
                      hi there..any update about to fix this?my set flick on off on Samsung Smart TV logo and loop on off again and again..what parts should be replace?
                      • cikgu
                        • Dec 2018
                        • Malaysia
                        #31
                        how to fix it.?anyone...?
                          1) What is your TV model number?
                          2) What Voltage testing have you done on the connector of the power supply board that goes to the main board? You need top provide the pin name and follow by the Voltage reading for each pin so we can see which Voltages, or Control Voltages are stable or not.
                          • Blackadderask
                            • Jan 2022
                            • Greece
                            #33
                            Hello i have the same problem with my tv.
                            the board is BN44-00427a and the tv is UE40D8000YSXXH
                            I check the board by eye but i didnt find an issue, now i have to check it with multimeter.
                            Any ideas hot to start ?
                              • 12322
                              • U.S.
                              #34
                              Checking solder joints is a good place to start, google is your friend for images of bad solder joints.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #35
                                maybe a software issue
                                https://www.youtube.com/watch?v=bJ8HSLlOwA8
                                • Blackadderask
                                  • Jan 2022
                                  • Greece
                                  #36
                                  Thank you very much for the help.
                                  I will try it and i come back to tell you the result
                                  • chico1234
                                    • May 2022
                                    • Spain
                                    #37
                                    Hello. This is my first post to de comunity. Grettings.
                                    I have a Samsung UE46D800 with BN44-00427a power supply whit a clicking trouble by a shadow bottom band . ¿Can you help me whith the fault component?
                                    Anoder cuestión, ¿It's BN44-00427b valid to change?
                                    Thanks.
                                    • steeven
                                      • Oct 2023
                                      • France
                                      #38
                                      Hello me too i have some problems but no schema , if u are founded the problem ? Thanks
                                        09-07-2024, 05:50 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
                                        Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 06:20 PM
