What does the model number mean?
  • mrbigsteel
    • Sep 2012
    • 17
    Found this web page that explains the meaning of HDTV model numbers for Sony, Samsung, Vizio, LG and Panasonic. May be useful to somebody.
    http://www.retrevo.com/samples/HDTV-Decoder.html
    Re: What does the model number mean?
    Also some things I've noticed.
    Samsung:
    PN = North American plasma (Canada/US)
    PS = Europe/Pacific/South America plasma
    UE/LE = European LED-LCD/LCD (possibly also Pacific/South America - not sure)
    UN/LN = North American LED-LCD/LCD
    Panasonic:
    TH or TX prefix: Europe
    TC prefix: US (possibly Canada too)
    • diamon
      Changing model number 5500 to 5510
      by diamon
      I would like to place a Dell Latitude 5500 (black color) motherboard into a Dell Latitude 5510 (silver color) chassis .
      How can I change the model number of this laptop?.
      When you're entering the bios (F12), you see in the left corner Latitude 5500, I would like to have this changed into Latitude 5510
      I have already edited the 5500 bios bin file with HxD, and changed the 5500 into 5510, but after re-flashing and soldering the chip back, the name in the left corner is still Dell Latitude 5510 (have entered the ServiceTag of the 5510 chassis).
      Have uploaded the original...
      06-19-2025, 03:25 PM
    • piernov
      Beginner's guidelines
      by piernov
      You have a laptop that does not power on, powers on but shows no image, crashes, etc… You want to fix it but you don't know where to start.
      There are 2 situations:
      1. You just want your laptop fixed
      2. You want to learn about fixing laptops
      Sorry, but if you're in situation number 1, we recommend you to use the services of a trustworthy professional repair shop.
      Unfortunately, if you're not serious about learning, you will waste your time and money, and you will make us waste our time as well.
      If you are in situation number 2, then please continue and...
      09-20-2020, 09:46 AM
      Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
      by sam_sam_sam
      This is a new item at Electronic GoldMine that has arrived within the last few weeks
      Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
      Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
      https://theelectronicgoldmine.com/products/g28392
      One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
      11-24-2024, 01:25 AM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • Valtekken
      Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
      by Valtekken
      Specs:
      • CPU=AMD Ryzen 5 3500U
      • GPU=(integrated) Radeon Vega Mobile
      • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
      • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
      Hello everyone.
      My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
      A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
      09-10-2025, 04:14 PM
