Toshiba 42HL196 LCD: Red blinking light
+ More Options
Posts
  • itshockedme
    • Sep 2012
    • 14
    I'm looking for some assistance troubleshooting the power supply board. I've done research and already replaced the most common components suggested by others for the TV not turning on with three blinking lights. After replacing Q820, Q860 and Q880, the TV was making a clicking noise and would not power on. Then, after replacing C888-C890 and D884A, the clicking noise returned when pushing the power button. So I'm back to three lights blinking and no powering up. I have the factory repair manual for reference and can give meter readings if someone can assist me in testing some components and/or any other suggestions. Thanks.
  • itshockedme
    • Sep 2012
    • 14
    Re: Toshiba 42HL196 LCD: Red blinking light
    Service manual
      Can you please tell me what pages those components you had replaced are in so I can see what their functions are.
      Right now the 5VSTBY is working, but I need to know if the PFC is working. Check the DC voltage on fuse F820 when the TV is plugged in but the power switch is not activated yet, then when the power switch is activated.
      Since you will working in the Primary side, make sure you do not touch any part of the TV with your body. You will be using the Negative leg of C820 (Large DC filter cap) as the reference ground point of the primary circuits for you meter black probe.
      • RON_CET
        • Jun 2012
        • 217
        Usually replacing Q820 correct 90% of this problem with the 3 blink power led attached is the smarttech guide for additional troubleshooting help right now my opinion is your having boot issues and have seen the SEIN board cause this 3 blink issue
        Ron Driver,BSEE,CET,ISCET,NESDA
        • itshockedme
          • Sep 2012
          • 14
          Q820 can be found on page 19 (from the toshiba manual).
          Q880, C888, C889, C890 and D884A can be found on page 21.
          Q860 can be found on page 22.
          I will be checking the DC voltage on fuse F820 right now.
          • itshockedme
            • Sep 2012
            • 14
            Thank you for the update on the troubleshooting info. It's very helpful.
              The info Ron provided looks like it may be the correct place to look since he has worked on this model before.
              • itshockedme
                • Sep 2012
                • 14
                Thanks budm, I really appreciate you taking the time to assist me. I feel like I've been up against a brick wall with this one. The DC voltage on fuse F820 when the TV was plugged in (power switch not activated) was fluctuating from 165.9V and 154.0V when clicking. Once the TV was plugged in, the relay was cycling (two clicks) consistently. The DC voltage on fuse F820 when plugged in and power switch activated was fluctuating from 167.0V and 153.6 when clicking. Are these readings within range? Any ideas on where to go from here?
                  I will have to study the circuits more and try to understand the info that Ron provided to see if it is relating to what you are seeing right now.
                  • itshockedme
                    • Sep 2012
                    • 14
                    Using the updated information posted by RON_CET (from the troubleshooting flow chart on page 4), I am getting a 3.28V reading on PIN 7 of CN49A. For some reason, I am not getting any voltage reading on PIN 5 of P812A.
                    • rlforget
                      • Sep 2012
                      Hi ISM,
                      I had exactly the same issue as you described and found the solution on the first try with only the internet as my guide.
                      On another forum, more than one person fixed this by replacing the STRW 6765 switch mode regulator on the main power supply board. Apparently very common on this set. If you haven't done this yet...
                      Three bucks on ebay and an hour and a half labor. Worked for me!
                      Good luck, Rick
                      • itshockedme
                        • Sep 2012
                        • 14
                        Originally posted by rlforget
                        Hi ISM,
                        Good luck, Rick
                        Thanks for input that is the same place I started also but no luck only clicking sound after replacing Q880 which is IC STRW6765
                        • itshockedme
                          • Sep 2012
                          • 14
                          uuhhggg..im stuck can anyone help me troubleshoot this power supply board??? Please I have meter an schematics and can take pics or whaterever is needed. Im know its not seine board because it powered on a couple times for a few seconds.
                            So, have you got good supply voltages from the power supply? If so, I would not suspect the power supply. (I have been mislead by those flowcharts enough to take them with a pinch of salt.)
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              You say it powered on a few times - I would suspect that there is an issue with the backlight inverter(s).
                              Other than that, make sure you replaced the startup cap in the power supply too!
                              Muh-soggy-knee
                              • itshockedme
                                • Sep 2012
                                • 14
                                Can you give me some tips on how to test the voltages from the power supply? I just want to make sure that I'm in the right area.
                                • itshockedme
                                  • Sep 2012
                                  • 14
                                  Is the large DC filter cap (C820) the startup cap in the power supply?
                                  • itshockedme
                                    • Sep 2012
                                    • 14
                                    Help!!
                                    • itshockedme
                                      • Sep 2012
                                      • 14
                                      With my meters negative lead on a ground where circuit board bolts to tv. And positive lead on top a heatsink im getting voltage reading..Does this mean i have a short?
                                      • naddaw000
                                        Toshiba 55U7863DG - green light blinking (17MB130S)
                                        by naddaw000
                                        Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                        I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                        12-02-2023, 01:35 PM
                                      • imranabbas
                                        Toshiba TV light blinking Red & Blue not able to boot
                                        by imranabbas
                                        Toshiba Smart TV 50u5865ee light blinking Red & Blue not able to boot what could be the issue
                                        where i can get Toshiba model 50u5865ee firmware
                                        Please check the attached rar file for video
                                        Please help urgently...
                                        11-27-2022, 06:31 AM
                                      • YasaCh
                                        Sony kdl 40p5500 red light keeps blinking 3 times
                                        by YasaCh
                                        Hello...
                                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                        i opened the back cover no sign of damage on the powery suply or motherboard
                                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                        07-07-2025, 11:53 AM
                                        09-06-2024, 05:27 AM
                                      • Fergal22
                                        TOSHIBA 40L3453DB red-green blinking light
                                        by Fergal22
                                        Hi, just need a bit of advice please
                                        I have a Toshiba 40L3453DB tv with the blinking red/green light and the light grey screen but no picture or sound
                                        there are no swollen caps as far as i can see
                                        I have searched the forum and found this thread for the smaller size tv
                                        https://www.badcaps.net/forum/showthread.php?t=58640
                                        which recommends redoing the firmware, so i have searched and the only firmware i can find is this one
                                        h**ps://repairalltv.com/toshiba-40l3453db-software-17mb95-download/
                                        the 17MB95 board is the same as mine but the...
                                        02-14-2021, 03:32 AM
