Akai LCT42Z76TA Backlight flashing on and off question
  • electronicsurplus
    • Jun 2012
    • 210
    Have an Akai LCT42Z76TA Backlight flashing on for a second and back off
    Power supply is perfect
    No 5volts going to BL Inverter. but, has constant 24V
    Flashes every minute for a second and back off
    Checked fuse on main board and has 12V only when backlight flashes on then loses it
    Any ideas would be appreciated
    Jonathan
    This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
    Help keep these from the landfills
  • learnmore
    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
    by learnmore
    Hello Community!
    CASE DETAILS
    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
    Tried inserting firmware on USB and left it in for a few hours, but no change
    03-03-2024, 09:49 AM
  • HTR-Informatique
    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
    by HTR-Informatique
    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
    I also changed the screen because the PC fell and the screen was broken.
    I changed the battery with a new and original battery.
    I also had corrosion/oxidation on the...
    02-09-2025, 06:51 AM
  • The_Todd
    Akai AK5519UHDS TV LED backlight issue driving me Insaine
    by The_Todd
    Hello, so I have a backlight issue that's driving me insaine.
    The tv is an AKAI 55” 4K ect ect, tv that turned on but no backlight.
    Used a backlight tester and of course, no lights. So spent the good part of 2 millenniums taking off the panel, replacing a single blown LED, testing with my LED tester again, they all turned on, however slightly dim. Put the tv back together and .... nothing....
    To make a long story short, the power supply ramped up to the 140-170v to run the backlights but after a second the voltage drops down to 0v, and the tv keeps...
    07-10-2021, 01:37 AM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • STKR123
    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
    by STKR123
    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
    I wonder if re-flashing the BIOS might be of any use here.
    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
    11-03-2024, 06:58 AM
