Panasonic plasma Th-50ph9uk.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    Panasonic plasma Th-50ph9uk with stby light blinking 2 times.
    Re: Panasonic plasma Th-50ph9uk.
    You know my question. Got the SM...?
    2 blinks is power SOS. If your PSU is similar, try this:
    http://www.youtube.com/watch?v=LjpGKaBt8hg
    • SEAWOLF
      • Nov 2011
      • 177
      Yes I have the SM.
        Is your PSU similar to the PSU in the video?
        • SEAWOLF
          • Nov 2011
          • 177
          The PSU is not similar to that in the video.
            Check if you have Vsus around 200V.
            • SEAWOLF
              • Nov 2011
              • 177
              On Monday I was checking the PS and I saw smoke on the lower right C6 board.When I examined the board I discovered that C617 a SMC was burnt.
              I checked the parts list in the SM but I did not see this capacitor,therefore I
              now have another problem to solve.
                You may in fact have a shorted COF on the panel column drivers, which would mean the TV would be unrepairable. Did you buy it as a faulty TV from someone or do you fix TVs for a living?
                • SEAWOLF
                  • Nov 2011
                  • 177
                  This plasma belongs to the church where I worship and it shut down about 2
                  weekes ago.
                    weekes ago.
                    Churches have plasma displays now? Anyway... if it is in untouched condition, I would first try and locate the power board problem. Unplug the "C" board with the failed cap for now. Those SMD caps can sometimes fail from vibration/movement and the problem may be completely separate. You should still get a pic on half/a third of the screen.
                    I saw a Panasonic plasma in my local bank with 2 blinks. Considered asking them about it but when I got it back they had replaced it with a new LG LCD/LED display.
                    • jm1234
                      Panasonic plasma TX-P42ST50 - 6 blinks
                      by jm1234
                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                      I checked that board for any obvious faults...
                      05-22-2024, 06:59 AM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • Eaglecrest
                      Panasonic plasma color stripe
                      by Eaglecrest
                      I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
                      11-05-2025, 06:16 PM
                    • Alicat
                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                      by Alicat
                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                      Model number is TH-50PZ85U
                      Power comes on and the red power light stays on solid.
                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                      I also hear a few clicks.
                      I also think my parents said there was a thunderstorm and the TV failed after that.
                      Section 6 in the service manual talks about power and no screen,...
                      10-30-2024, 10:09 AM
