Panasonic plasma Th-50ph9uk with stby light blinking 2 times.
Panasonic plasma Th-50ph9uk.
Re: Panasonic plasma Th-50ph9uk.
You know my question. Got the SM...?
2 blinks is power SOS. If your PSU is similar, try this:
http://www.youtube.com/watch?v=LjpGKaBt8hgPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
http://www.youtube.com/watch?v=LjpGKaBt8hgComment
Is your PSU similar to the PSU in the video?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Check if you have Vsus around 200V.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
On Monday I was checking the PS and I saw smoke on the lower right C6 board.When I examined the board I discovered that C617 a SMC was burnt.
I checked the parts list in the SM but I did not see this capacitor,therefore I
now have another problem to solve.Comment
You may in fact have a shorted COF on the panel column drivers, which would mean the TV would be unrepairable. Did you buy it as a faulty TV from someone or do you fix TVs for a living?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
weekes ago.Comment
Anyway... if it is in untouched condition, I would first try and locate the power board problem. Unplug the "C" board with the failed cap for now. Those SMD caps can sometimes fail from vibration/movement and the problem may be completely separate. You should still get a pic on half/a third of the screen.
I saw a Panasonic plasma in my local bank with 2 blinks. Considered asking them about it but when I got it back they had replaced it with a new LG LCD/LED display.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by jm1234Hi,
anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
I checked that board for any obvious faults... -
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... -
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
by LintesirMy parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
There is about a 5cm high region at the top without any sparkles,... - Loading...
