Panasonic TC-P50G10B - flashes 7 times, stuck in standby
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G10B - flashes 7 times, stuck in standby
    What do you think about IC581(IC16581) Volatge error Detect at <67V and 139V or more? What's that monitoring?
      I guess that's involved in SOS6. In fact, you make a good point - it looks like it might just measure the average voltage going to the panel buffers. If the drive circuit wasn't getting power, it could explain SOS6, because there would be zero average voltage. May explain why disabling SOS7 triggers SOS6. I didn't realise that. Thanks!
        Here's a picture of the SC and of the suspect failure: a little hybrid module responsible for generating +16V_F along with +32V_F.
          Hybrid module is fine... just tested it to be sure. But still not getting any good 16V at the error detect circuit.
            Blue trace is error signal, yellow is 15V power. You can see that the error is causing the 15V to shut down.
              Shoulda tried it with the buffer connected, it uses the plasma panel to build up energy on the energy recovery caps, without the buffers the 5.9V for the regulator didn't come up, but that's working now, so it must be one of the other four protections. But I feel like I'm pretty close to finding out the problem.
              • tw2005
                • Oct 2011
                • 6458
                Are you testing with no buffers connected?
                • tw2005
                  • Oct 2011
                  • 6458
                  To test set with any of the SU or SD boards disconnected there is a White 2 pin connecter, SC50 located bottom left hand corner.
                  Jumper these pins and the set will fire up as normal
                    Many thanks for that tip. I'll have to keep that in mind for future. I think the buffers are OK on this one... but I suppose I haven't tested it as it gives 7 blinks with and without them and the error code corresponds possibly to a buffer fault. I'll try it tomorrow when I get some more time. Does it work with one buffer only, or do both need removing?
                    • tw2005
                      • Oct 2011
                      • 6458
                      You had to ask. Not sure. I disconnected a LG buffer once but forgot to isolate it from the other and it smoked. Lucky it was the bad one so get get a bit nervy about it now. I like to remove them completely out of the set these days.
                      I'll see if I can find the manual I got the procedure out of. My gut tells me your fault will be on the SC. These time zones are fun. I get up as you hit the sack.
                      What is it 10:35pm there(7:35am Mon here)
                        22:42 here.
                        I'll try with both tomorrow. Have run this set with one with no smoke - but still 7 blinks - of course that might mean no sus waveform... Not like the older TX-42PZ70BA. I had that running with just the upper buffer and got half a picture. Makes sense don't know why the newer ones don't support this.
                        I left my nice fixed 10X probe at home, and my other switchable 10X probes are only 300V rated, so I can't probe the sustain waveform at the moment . I will see if I can borrow a fixed 10X probe rated for at least 500V.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Not this model but 12th Gen which yours is. They even rate the likelyhood of which bits most likely for the SOS7 trigger.
                          It's the 11th Gen manual i think for the rundown of board isolation. I have it somewhere.
                          • tw2005
                            • Oct 2011
                            • 6458
                            22:42 here.
                            Any part of those buffers disconnected and I'm pretty sure it won't fire up at all. You have to jumper the SC.
                              Thanks for the link. I've only been working off schematics in the service manual. Didn't consider that there might be a training manual. Plasmas are fun for me to work on though. I love fixing them even if they can be more tricky sometimes (though, you can get lucky...)
                              • tw2005
                                • Oct 2011
                                • 6458
                                The best thing in the Trainers is the extra tips and sometimes the anomalies with some of the fault codes they sometimes find.
                                Like any self diagnostic function it's a start point not always what the true fault is.
                                I worked on a system which was pretty smart with its self diagnosis but watching techs order every part listed without doing their own analysis was amusing at times when they still did'nt fix it.
                                I do find fault find these panasonics tricky at times and complex. Sometimes just bite the bullet and get the board but finding that one component is rewarding.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Ok I think it's this one that goes into the buffer board isolation procedures. Not quite the one I read but I think that jumper connector was added later. This gives individual tests using alligator clips but pretty sure you just need to jumper that connector.
                                  P63. You can download to get the full story
                                  There was also a recommendation not to run for more than 30secs with any board disconnected.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Sure hope you can component level repair the SC board. Can't find them anywhere. makes you wonder if they were a dud.
                                      OK, got the thing to do 6 blinks now I've got the buffers fixed on. Still no picture, so I looked elsewhere.
                                      SOS6 simply measures the voltage on the energy recovery caps. This should be between 67V and 139V as you mentioned earlier. It's just about hitting 64V, so it's nearly there... and I suspect if it does hit 67V, then the D board will start liking it and start sustaining the panel allowing ER to rise much higher.
                                      I need to figure out how the ER/MID voltage is generated.
                                      The VSC1 output - the sustain drive - is looking a bit poor; it's only peaking to about 70V, when it should be close to 200V with 290V Vset peak.
                                        It looks like the cause may be that the VOH transistor/IGBTs are not firing - none of them are. I need to check how gate drive is generated for these IGBTs. I think the devices themselves are OK but I am not certain yet.
                                        SS appears to work for a subfield as it is generating what looks to be a reasonable wave.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          The fact they don't fire would that simply be because the protection cct is activated?
                                          • provider22
                                            samsung UA32d4OO RED LIGHT FLASHES 3 TIMES
                                            by provider22
                                            11-19-2025, 02:45 AM
                                          • Egidio85
                                            Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                            by Egidio85
                                            Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                            the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                            the fan does not start.
                                            I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                            any advice on what to check?
                                            06-10-2025, 05:00 AM
                                          • BobbyMJ
                                            Panasonic TC-P60S30 - no standby voltage
                                            by BobbyMJ
                                            Hi All,
                                            Wanting to learn some electronics repair skills.
                                            I found a non working Panasonic TC-P60S30 and this is my first project / attempt.
                                            So far I have found a blown cap on the main power supply board.
                                            After replacing it there's still no standby power.
                                            Poked around and found a resistor on the PSUB power supply board that measures open.
                                            An online resistor calculator shows this is a 93k ohm resister.
                                            My questions:
                                            Is that correct, 93k ohms?
                                            Is it a fusible resistor?
                                            Lastly, how do I know what wattage?...
                                            05-14-2025, 06:42 PM
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • esqmooo
                                            HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                            by esqmooo
                                            I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                            03-07-2025, 05:55 AM
