I have a samsung 360 watts power supply BN44-00161A very dificult to find a working one and i found a exactly same one whit the same conectors BN44-00190A but this one have 460 watts,are you guys believe this gonna work thanks for your answer in advance.
SAMSUNG PLASMA TV HP-T4264 Power Supply Replacement
Tags: None
Re: SAMSUNG PLASMA TV HP-T4264 Power Supply Replacement
I did not know plasma TV supplies were rated in watts. What is the fault with your PSU - maybe it is repairable?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
As long as the outputs are the same, it shouldn't be a problem. The wattage is most likely in reference to power consumption, or in other words the second one is less efficient.
BUT, I would let tom help you to work on your existing power supply, definitely a lot cheaper to do so and helps other people with the same problem.Comment
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
These have been verified to work with the set alternatively to 61a
BN44-00159A
BN44-00188A
The 90A I'm not sure, It is meant for the 50" as tom said but try your luck with those.
THOUGH, the 61a can be used for the 50" versionLast edited by drpj23; 09-20-2012, 04:25 PM.Comment
I just order the 190a this one is for a 50" tv and have the same outputs voltages i will post back when installed thanks.Comment
Continuous clicking usually points to Y- or X-main fault, not PSU. Did you try isolating the sustains and seeing if it still clicked?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I have had a 50" that did this and it turned out to be PSU dry joints on a bank of FETs as well. What bits did the kit cover?Comment
Yes you totaly right i replace the PSU and the clicking continue I did my test and found that the clicking is when conect the Y board i will tried to find was wrong at component level,a tech tell me that is cause for the short IC if some one now about this any hepl is apreciate.Comment
Try without the buffers - the green board connected to the Y-main.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by alltvrepairsHi,
I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
Any one met this problem in the past?...10-08-2025, 07:34 AM -
by lp20thI have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by r2digitalI have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...2 Photos
Assuming...7 Photos - Loading...
