Vizio vw42l fhdtv10a
  • Mr Senior
    • Sep 2012
    • usa
    I have a vizio vw42l which was zapped by a power surge. it wont come on by remote or buttons on tv, i have no backlight or front led. Tried replacing power board and i have same problem. could someone inform me on how to test the other main board as well as any other boards that may be damaged. Is there another fuse i am missing?
  • drpj23
    • May 2012
    • 528
    Re: Vizio vw42l fhdtv10a
    There are 2 fuses on the main board - check to make sure they are ok by checking if it is under 1 ohm.
    They are surface mount near the connector J1.
    • retiredcaps
      • Apr 2010
      • 9271
      In addition to the fuses as per drpj23
      See my sig file for
      1) how to post pictures
      2) how to test a voltage regulator (especially if it is a Vizo)
      --- begin sig file ---
      --- end sig file ---
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Using the search function on this forum, there are a only about a hundred or so posts about this same set, and same problem. I hope you didnt spend too much changing out the power board. Then again, you can sell the other board after you get it working and can properly test it to show good.
        As for now, you can test all of the mainboard LDO regulators as seen in other threads on this model. If you're not looking to go that far, just buy another mainboard. Make sure you match up the numbers with your board.
        Have fun.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • ken_taz
          Vizio VW42L FHDTV10A will not turn on without unplugging and plugging TV back in
          by ken_taz
          Summary
          Vizio VW42L FHDTV10A will not power on without unplugging and re-plugging the TV back in several times.
          Problem
          The TV will not always act the same way when it is plugged in to try and get it to start up.
          First, I plug the TV in and get the Vizio logo to light up orange. Press the button to turn it on and nothing happens.
          I then unplug the TV and wait a few seconds and re-plug it back in. This time when I press the button, the Vizio logo turns white, but no back light comes on. During this time the outputs...
          06-08-2018, 09:34 AM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
