Polaroid TLX-04243B Horizontal Lines/Bars
  • kevinm34232
    • May 2012
    • 1884
    TV functions but with screen split in half horizontally and then to 4 horizontal quadrants, with black lines racing through. Reseated ribbon cables no change. Trying to determine if a main board, t-con, or panel problem..
    T-Con: AUO 55.42T02.C02
    Panel: T420HW01 V2
  • kevinm34232
    • May 2012
    • 1884
    Re: Polaroid TLX-04243B Horizontal Lines/Bars
    Ordered a T-Con board because not very expensive, just wondering if you guys have any guesses, have you seen a main board cause this?
    • kevinm34232
      • May 2012
      • 1884
      Replaced T-Con board, problem persists. Ready to part out TV just not sure if it's main board or LCD panel causing issue... If I disconnect 1 ribbon on the T-Con board going to panel, half the screen vertically does same thing, the other half is steady white with some vertical colored lines. Not sure if that indicates anything..
      Anyone know how I can determine?
      • drpj23
        • May 2012
        • 528
        That does not sound too promising.
        Can you include pics of it?
        To be on the safe side, check voltages and regs on the main.
        What's the panel model?
        • kevinm34232
          • May 2012
          • 1884
          Pics and panel # in first post..
          • drpj23
            • May 2012
            • 528
            Oh sorry about the panel number but I meant pics of the half screen with white on one side.
            If you care to, I have found the panel for 150 (not including shipping).
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • ggil44
              Sony XBR-65X750D Horizontal lines bottom of screen
              by ggil44
              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
              05-30-2023, 07:51 PM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • noipi
              samsung Oled 65 Horizontal Lines and Flicker
              by noipi
              I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
              10-14-2025, 02:11 AM
