Sony KDL-32L4000 Double image
  • Mr Bill
    • Nov 2011
    • 648
    The top 2" of the screen is pefrect but below that point the screen is blurry and showing a double image. I thought this would be a bad tcon board but i got a replacement from Shop Jimmy today and it didn't correct the display. Is it possible to have a faulty tcon? Can a faulty TAB do this? I would think it would be from the top of the screen to the bottom but i haven't had a tv with a loose tab yet. Twisting the screen doesn't seem to do anything and there is no slow motion or darkness.
    I am going to disassemble the panel and see if the tabs are loose. Just getting some feedback and see if i'm wasting my time. The panel is a Samsung LTY320AB01
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL-32L4000 Double image
    Wow we are having the same issue. Is your panel underneath the good section jumpy and at times show a smeared image from what's on the top? Check out my thread. Mines an auria 32" with a Samsung LTA320AB02 panel. My good/bad line is 6" from the top. Everything under that is vertically jumpy and smeared.
    https://www.badcaps.net/forum/showthread.php?t=23205
    • beetle1303
      Sony KD-65X7000E - Screen double images for first few minutes then back to normal
      by beetle1303
      I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
      Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
      1) On power up - display double images, and flicker once every few seconds.
      2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
      3) Leaving on for few minutes, power off and on again will repeat the same...
      03-11-2023, 02:07 AM
    • dicky96
      HP Elitebook Screen blank - backlights but no image
      by dicky96
      Hi guys
      I'm trying to fix this laptop screen
      Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
      OK so I have the original screen which works but has lines across the bottom quarter of the screen
      I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
      04-28-2021, 07:30 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • rimwall
      Sony KD-65x7500D - double image - Tcon or Panel?
      by rimwall
      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
      11-18-2025, 02:09 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
