auria 32 inch LCD half screen jumpy
  • freakaftr8
    • Oct 2012
    • 3743
    Ok I have messed with and repaired alot of LCD/plasma tvs in my day but this one is confusing me. Samsung made panel and tcon with off brand mainboard. What this tv is doing is just a little before half way there is an obvious horizontal line and everything under that line is vertically jumpy, and a times double or triple or depending on what showing on the screen vertically smeared all the way down. as you can see the top good portion of the screen is smeared underneath that line. above the line, completely normal. this seems to get better and worse but never goes away.
    i have watchged youtube videos showing some Sony KDL series 32" screens doing something siimilar and the dude hit the tape carriers with freeze spray, coreecting this. on this set, I have already pressed on the connectors, flexed the screen, hit tcon and mainbboard with heat, replaced lvds ribbon from tcon to panel, cecked voltages, tested regulators, etc.. Nothing makes a difference.
    Have you guys seen this and corrected it before? Im of the assumption that its a tcon. This panel only uses one ribbon from tcon to panel.
    Thanks,
    http://i845.photobucket.com/albums/a...r/IMG_4076.jpg
    http://i845.photobucket.com/albums/a...r/IMG_4075.jpg
    http://i845.photobucket.com/albums/a...r/IMG_4070.jpg
    http://i845.photobucket.com/albums/a...r/IMG_4067.jpg
  • drpj23
    • May 2012
    • 528
    Re: auria 32 inch LCD half screen jumpy
    This looks similar to yours (it is a sony KDL too)
    https://www.badcaps.net/forum/showth...sony+bad+panel
    I would see if Mr Bill fixed it or not.
    If it is not TCON then panel is all that is left.
    • freakaftr8
      • Oct 2012
      • 3743
      Hmmm I'm thinking it may not be a tcon after reading his thread.
      Btw panel is Samsung LTA320AB02
      Tv model auria EQ3299
        I've seen that symptom on a 40" Samsung panel and it was the LCD panel. Though it was just tab bonds and fixable.
        http://www.youtube.com/watch?v=vCExlSnG4yY
        • Mr Bill
          • Nov 2011
          • 648
          It's a bad panel . I tried the tabs on my KDL-32L4000 and i got the same results you got.
          • freakaftr8
            • Oct 2012
            • 3743
            I was thinking that. Oh well it was only 20 bucks and some time spent.
              It may be repairable if you want to tear down the LCD to the tabs.
              • Mr Bill
                • Nov 2011
                • 648
                What are your suggestions Tom. My panel on my KDL is on revision older but the same symptom. I'm wondering if it's something in the panel card that's bonded to the screen.
                  Well, if you're gonna trash it, may as well have a look, see if you can apply the fix as in the video.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I have torn mine down to the tabs already. Pressed on the tabs. Applied pressure and tried a little heat. Also checked tab bonding on the top boards of the lcd too. Have not tried freeze spray yet.
                    There are no visable issues with the tape carriers as far as I can tell. No burns or cracks.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      I'm Going to get some freeze spray with the tabs and panel cards exposed and try it tonight.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Well freeze spray didnt help. But here's the odd question. When I loosen the lvds cable from tcon to panel and start to fiddle with the connections like barely making contact. The interesting thing is well of course the picture gets wierd. But the flicker goes away. Of course the screen redraw us slow. I'm thinking tcon now.
                          When the T-con starts going crazy, the panel might not get the right signals - it's 90% likely the panel is at fault here. Strip it down and check the tab bonds.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Tabs seem fine. I've done all I can with the panel tab bonds in the way of pressing on them poking an prodding. Lol. Also tried heat and freeze spray. Nothing seems to affect the issue. Stays the same
                              It's probably permanently failed then.
                              • Mr Bill
                                • Nov 2011
                                • 648
                                I replaced the tcon in my KDL-32L4000 and it didn't fix it.
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Well since its junk I'm going to expiriment.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    I know this thread is old but just got around to replacing g the tcon and same issue but I hit the right side of the screen with freeze spray and issue goes away til it heats back up. The point of the problem is right at the line where it starts. When I hit it with freeze spray the screen immediately fixes itself. When it starts to reoccur there is a horizontal line then the jumpy distorted picture comes back.
                                      So you probably have a bad tab bond then.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        That would be thought as well but this is at the point of the side of the screen. Horizontally down the side like almost half way. The tab bonds are at the top.
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
