Re: Sharp LC-40LE810UN question
Don't forget there is error pin #6 on the connector which goes to main board
That will be his next step, but that means his main board is not sending the PS_ON which another problem he will have to solve also.Leave a comment:
You are right ,he has to remove all cable from power supply only 110v and apply PS_ON manually and see V on main capsLeave a comment:
As I stated in 204, I do not believe he is getting the PS_ON signal from the main board to turn on the PFC and the backlights and the PL on 12V transistor Q7908??? at the bottom right of the board close to the PL connector. He may have to apply PS_ON signal manually.
Aloha, please see post 206, which is what the error code he had indicated.Last edited by budm; 10-12-2012, 10:36 PM.Leave a comment:
Section 2 on that page says one slow flash and one fast flash is a lamp (backlight) error.
Fourth item down in sections 3 says that 2 slow blinks and 5 fast blinks is 12V panel power. (12V panel power is the t-con and LCD power, nothing to do with the backlight)Leave a comment:
There is not 12v because ( Panel power is not applied)
Detection is started after turning on the panel power and
receiving command; the power is turned off by polling
First needed working power 168v=OFF ~395v =ON on main caps,and working LEDs power supply.Last edited by olegi; 10-12-2012, 10:26 PM.Leave a comment:
So 2-slow, 5fast = PL 12V ERROR CODE.
OK, please tell me the voltage readings at those red circles, black probe to the chassis. We need to find out if we are getting 12v at the PL connector or not. I also need good pictures of that section.Last edited by budm; 10-12-2012, 10:14 PM.Leave a comment:
Ok, so it looks like it is not getting 12v feedback from the T-CON to tell the processor that it is not receiving the 12V. So I would suggest to look at the PL connector P4804 4-PIN to see what voltage he has on those 4pins. I can see that the power applied to this connector is supplied to the switching supplies on this T-CON board.Last edited by budm; 10-12-2012, 10:28 PM.Leave a comment:
Post 191 "Last week I had same model 60" (two long 5 short). SHARP 60" has full 4 LED strings .Problem was Only 1 single led of one string"
Post 197 "2 long, 5 short error rarely has anything to do with the backlights. If the power board is good, and you get the same error code with *both* cables between t-con and panel disconnected, that leaves the t-con board or LVDS cable.
Bad backlights give 1 long, 1 short error code"
Which one is the correct one? Looks like I will have to download the service manual to find out.
In the mean time, cam you leave the meter on pin16 and see if the VCC voltage even jumps up when you first turn on the TV, that way we can tell if it even try to turn on.Attached FilesLast edited by olegi; 10-12-2012, 09:14 PM.Leave a comment:
OK, you are working on the original board and you had fixed the switched 5V and the switched 13V supply, but the PFC is still not working, so for the PFC to come on, the main board will have to send the PS_ON to turn on the PFC, but since you are getting the error code, then we need to really find out what that error means since we got two answers for it.Leave a comment:
I'm measuring before the error code.Leave a comment:
I think we have to hold on a bit with all these ideas.
We get carried away and we are not covering the basics.
Right now I'm using the original board and it seems that is working "OK" up to a point.
I'm saying it's OK up to that point where are the two capacitors(brown and black), there I have the 5.5V respectively the 13.2V.
Another problem is that I'm seeing is that the 13.2V it's not reaching the mainboard. Only the 5.02V goes through.
If I measure the two power double diodes, at the middle pins I should measure 5V respectively 13.2V, no? The 13.2V it's not there.
No 400V either, only the 168V.Last edited by Alohamora; 10-12-2012, 07:18 PM.Leave a comment:
No 400V either, only the 168V.Leave a comment:
So right now we are working on the replacement board that you installed because the old one will not always get the 5 and 12V output. And the voltage on the two large caps on primary side does not jump up to 400V either?Leave a comment:
Tha is what I did and from 0.3V went to 0.8V and when the code came up went even more down, to 0.009V.Leave a comment:
In the mean time, cam you leave the meter on pin16 and see if the VCC voltage even jumps up when you first turn on the TV, that way we can tell if it even try to turn on.Leave a comment:
I have tried disconnecting each cable at a time from the T-con, with no change.
At this time I'm suspecting the LEDs in the panel.
I will take it apart.
Replacement power supply/inverter board didn't change anything(hopefully it was a good board from partstore), removing the EEPROM didn't change anything, there is only the LCD panel left.
Bad backlights give 1 long, 1 short error code.Leave a comment:
36BS03LJ.
It makes sense, since I'm not getting any increase in voltage at startup.Leave a comment:
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-12-2024, 02:30 PM
This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 08:10 PM
- Loading...
