Sharp LC-40LE810UN question
    replied
    Re: Sharp LC-40LE810UN question
    As you can see, there are two transformers that supply the power to the LED strings, one per string, It has to be some thing in that LED drive power supply whcih is common to both strings. Bothe transfoemrs primary are connected in series and driven by the the same set of MSOFETs Q7601A/7601A setup as a half bridge drive. Which IC that you blow when you short the Opto? U????
  • tibimakai
    replied
    I will give it a try. Thank you.
    I guess it would be very good if we could start the inverter to make sure that it starts, but I don't know how come last time blew that IC.
    You are sure that that's the opto for that?
  • olegi
    replied
    Last week I had same model 60" (two long 5 short). SHARP 60" has full 4 LED strings .Problem was Only 1 single led of one string. Tv was very hard to disassemble , because of the size (very fragile to ) Hope this helps.
    Backlight diodes http://www.sharpsma.com/lighting/led...es/GM2BB45BMAC
  • tibimakai
    replied
    What else can I try?
    I'm becoming frustrated, I have three monitors(2 small TVs) and three TVs that I'm having a hard time fixing them.
    42" LG shorted PS, 42" Philips 7422D/37 no power, 24" Asus w/blown components, 22" LG M2262, 22" Samsung w/mystery PWM chip.
    replied
    I do not think it will be bad LED assemblies since there are at least two strings of LED and I doubt that both of them went bad at the same time. Iworked on LED backlights monitor last week and one of the pin on the connector for one of the sting was bent, the other string still lights up.
  • tibimakai
    replied
    I have tried disconnecting each cable at a time from the T-con, with no change.
    At this time I'm suspecting the LEDs in the panel.
    I will take it apart.
    Replacement power supply/inverter board didn't change anything(hopefully it was a good board from partstore), removing the EEPROM didn't change anything, there is only the LCD panel left.
  • Alohamora
    replied
    Originally posted by tibimakai
    Do you mean on the bezel? If yes ,then yes the same as before two long and five short blinks.
    Should I take the LCD apart to check for bad LED?
    No. 2 long & 5 short is 12V panel power, i.e. t-con problem or LCD panel short.
    Disconnect both of the flat cables between the t-con and the panel, then power it on. What happens?
  • tibimakai
    replied
  • tibimakai
    replied
    No. I measure 0.009V at the LEDs. At one connector the voltages are positive and at the other are negative. I'm affraid to toch again the opto. It will take more then two weeks to get new ICs.
    replied
    any LED-ON signal or similar coming up?
  • tibimakai
    replied
    Ok, I'm back with the error code blinking.
    I had to replace the 3BS03LJG IC, I was lucky to have an extra one.
  • tibimakai
    replied
    I have placed the DMM probes to the LED DRV. pins and I have started it up, then I have touched the two pins on that opto and for a second the light bulb(I have a short circuit tester with a 100W bulb) turned on and then off. Then the V Led did not tun on. All this time the voltage haven't changed, stayed at 0.009V.
  • olegi
    replied
    What did you do exactly?
  • tibimakai
    replied
    I couldn't find the diagram. The SM from elektrotanya doesn't show the power supply.
    Now I have bigger issues, I have to find the bad component.
    Bud, could you please look at the Samsung 2333 please?
    replied
    That opto may be for the voltage regulator feedback, need to find out if that is the correct opto. Need to find the diagram for this board.
  • tibimakai
    replied
    I have measured the voltages and there is not much change. On the upper connector I had +0.009V on both pins and on the bottom connector I had -0.009V on both connectors.
    I have tried the replacement board also, and it measured exactly the same.
    When I shorted the opto, the bulb on the short tester outlet lit up and since then I don't have any voltages and no LED light on the front of the TV.
    The only voltage that I have is the 170V on the main caps.
  • olegi
    replied
    Ok. All cables has to be attached (specially those for LEDs led_drv1 and led_drv2) Power up tv,wait ~ 10 sec. Voltmeter has to be attached (neg to ground) ,with positive probe you have to check each pin on LED_DRV (1 an2 , +and -).DC voltage should be ~ +95v -95v depend of different factors .If you have ~0v,then you have to manually turn ON backlight inverter .By looking on yours particular board optocoupler PC 7702,turn backlight On.You have to short with INSULATED scrwdriver ,PRIMARY side of optocoupler as is shown on the picture (don`t short any of the other optocouplers,do not mesure primary side circuit HI VOLTAGE HIGN FREQ),then measure readings.Post result.
  • tibimakai
    replied
    I have measured the LED voltage, early before I left to work and measured from the secondary ground and I'm getting on all the pins 0.0019V.
    From primary ground I'm getting 28.6-28.8V.
    But I think that I have to measure from the secondary.
    I have tried even without the LEDs and I'm getting the same voltage.
    When I will be home, I will try with the replacement board, to see if I'm getting the same voltage.
    I guess these voltages should be DC voltages, since the LEDs are diodes.
  • olegi
    replied
    I read this guide 2 seconds to black
    (https://www.badcaps.net/forum/showthread.php?t=10419) and your tv it is bit differant
  • olegi
    replied
    This Tv, when you press power on button it is dark ~ 5sec then lit up.
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-06-2024, 08:10 PM
