Sharp LC-40LE810UN question
  • tibimakai
    replied
    Re: Sharp LC-40LE810UN question
    Thank you for helping me.
    It's to late now, I will measure it tomorrow.
    I was wondering about this startup on LED TVs, they don't have the 2 sec to black. as LCD TVs with CCFl tubes?
  • olegi
    replied
    This power should have 2 pair of LEDs divided in 2 section total 4 wires .Can you check with voltmeter what you have on connector LED_DRV1+ and - as well LED_DRV2 + and -.You have to attach voltmeter before you power the tv,then power up and see what is the reading from each pin. Post results.
  • tibimakai
    replied
    I have never repaired an LED TV which required work on the backlight. How do I know which one is bad?
  • olegi
    replied
    Originally posted by tibimakai
    I don't have backlight. I have purchased a power suppliy from partstore.com and it showed the same error code with it. I have to check on the capacitor, I haven't noticed it.
    Your backlight is made from LEDs. In this case check for open LEDs on backlight.Do not buy new eeprom for now(you have to remove the error )
  • olegi
    replied
    Originally posted by tom66
    We went over that - it's a surge protection device, not a problem or the fuse would blow.
    Interesting if an LED in the backlight is dead. Should be easy enough to replace it or disable it (barely noticeable) - but it seems to be a common fault, seen a few sets like that here with dodgy backlight connections or open LEDs.
    Just want to get my hands on one .
    I use the same picture from post 1 and i was refering for second circle bottom .You are right ,it is like open LEDs(backlight)
    replied
  • tibimakai
    replied
  • olegi
    replied
    Basically this error means (with cleared , removed eeprom)if you are sure that your power supply board is OK ,you have burn led diode in backlight.I check from your post #1 ,there is burnt capacitor in red circle.Can you confirm?
  • tibimakai
    replied
    I think that the easiest for me it would be to just purchase a new one. The question is which one, on Digikey there are a lot of choices.
  • olegi
    replied
    Ok don't put it back .Check this .According to service manual:
    Power PWB failure Flashes 2 times (twice slow) after that
    Flashes 1 times Power supply error 1 (*2) AC_DET error
    Flashes 2 times Power supply error 2 (*2) UR+13V error
    Flashes 3 times Power supply error 3 (*2) D3.3V error
    Flashes 5 times Panel power supply error
    PANEL_POW Panel 12V failure Flashes fast 5 times
    DET_PNL12V(35pin) failure (L). Panel power is not applied.
    Detection is started after turning on the panel power and
    receiving command; the power is turned off by polling.
  • tibimakai
    replied
    Ok, I have removed it and it's the same code.
  • olegi
    replied
    Don't do shorting pins .Can you desolder that chip .Power up with removed eeprom chip.Tell what is the blinking code.What i think after a few unsuccess power ups (errors ) , firmware write code in this chip to prevent from further power on(may be for safety )
  • tibimakai
    replied
    Thank you.
    So, there is an error stored on the EEPROM and that error doesn't let the TV to turn on?
    Why that error came up in the first place, what caused it?
    I see on the net that these chips can be cleared with a paper clip, what is your thoughts about that? Between pin 3 and 6.
  • olegi
    replied
    Hi tibimakai, i check today and that chip is IC2004 and is it 24c02 not 24c04.You can find it on the back on the board in red circle .That was in my tv before i erased.Hope this helps.
  • tibimakai
    replied
    I understand, but I'm having a hard time figuring out which one is that eeprom chip.
    replied
    ^Reply to budm on why there's no reset button not relevant to your problem.
  • tibimakai
    replied
    Which one is that chip?
    replied
    Originally posted by budm
    Darn, they have to make it so complicated. Why can't they put a simple clear button to clear out the garbage from the chip, but then they cannot sell more TV, I guess.
    Because then you need a microcontroller or some processor to erase the chip - which adds expense - and TVs are really slim margin so where-ever cost can be cut...
  • tibimakai
    replied
    I don't understand which IC I have to replace. No matter which one, it.doesn't look easy at all.
  • olegi
    replied
    Consider your tv it is like computer.
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
    by sam_sam_sam
    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
    I am comparing them to a brand new one that I installed
    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
    I going to let it run for several days before I remount back on the wall next to the...
    09-05-2024, 06:48 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
    09-06-2024, 08:10 PM
