Re: Curtis lcd3215a Standby power only
Quote from retiredcaps''The main board uses the PS_ON pin to tell the rest of the power supply to start. If PS_ON is low, then the power supply will not start.'' end quote
I might be misunderstanding you,but the blue wire that is PS_ON, only has voltge (5v) on it when power button is turned on.
No voltage when power button is off.
The purple wire has 5v on it at all times.(would that mean that is the standby power for the main board?)
So if the main board is sending 5v through PS_ON to the power supply,wouldnt the 5v its getting be HIGH(on) and 0v be low (off)??
Or is it suppossed to be higher than 5v to trigger power supply??
Sorry if i'm misunderstanding you.
Also how do i Quote just part of somebodys post and get it to show up in blue like you are doing?? I cant figure it out!! Man! not only am i a noob at electronics and photography! im also a noob at forums!! lol sorry
You have at least 3 voltage regulators on your main board, possibly more, but the main board picture is obscured by wiring and the angle shot.
See my sig file on how to test a voltage regulator.
Note to selldoor. There are no regulators on the back although I do see a few diodes.
u18
78d051
ebvhab
pin 1 = 0.39v
pin 2 = 0.00v
u11
vc33c
r133al
pin 1 = 0.00v
pin 2 = 5.11v
pin 3 = 3.30v
u15
eh13a
828n90
pin 1 = 0.00v
pin 2 = 0.00v
pin 3 = 0.45v
u2
eh11a
839k32
pin 1 = 0.00v
pin 2 = 0.00v
pin 3 = 0.45v
u4
eh13a
828n90
pin 1 = 0.00v
pin 2 = 0.00v
pin 3 = 0.00vLeave a comment:
Note to selldoor. There are no regulators on the back although I do see a few diodes.Last edited by retiredcaps; 08-28-2012, 11:35 PM.Leave a comment:
When you get any sort of power LED light (red, green, flashing), that automatically tells you that the 5V standby is working. Since 5V standby is working, there is no need to test the bridge rectifier. If the bridge rectifier were bad, you wouldn't any DC voltage.
Should i pull the 4 rectifiers out of circuit to test??(I can post pic of how there in circuit if needed)
I dont know how to test the transformer.
http://www.anatekcorp.com/bluert.htmLeave a comment:
0.40v on all ends when power button hit, but steadily drops to 0.05v on all pins within about 30 seconds.
Meter set to 20v scaleLeave a comment:
can you check what voltage you get at each end of the 2 main board fuses
can you post pics of the back of the main boardLeave a comment:
tested 1.5v at the pins where i disconnected the inverter wires
sorry gotta go to work,be back on here in about 8 hrs
Thanks i really appreciate it!!Last edited by allsmith; 08-28-2012, 06:05 AM.Leave a comment:
Please can you check if the 24V comes up without the inverter connected.Leave a comment:
Here is a close up pic
Thanks!!Leave a comment:
Perhaps check the soldering on the transformer the pin just to the left of the third row down of 6 wide ventilation holes looks a bit off and this is in the hot (singed)area.Leave a comment:
379v when power button is pushed to on.Leave a comment:
Same test results as before
0.10v when pluged into wall
5.0v after hitting power button
Green led stayed solid on this timeLeave a comment:
Another test - voltage across 450V cap should increase when you press the power button - should be around 400V when running, 165V when "off".Leave a comment:
OK, so main board is probably okay, but voltages aren't coming up.
Can you try without the inverters and other 24V cables disconnected?Leave a comment:
Blue wire goes to 0.10v when tv is plugged in. DMM set on 20v
When power button is pushed voltage on blue wire goes to 5.0v
Stays at 5.0 even after hitting power button to turn off
Just seen a post of a you tube video that there is a thermal fuse in some transformers,could that be a possibility?
Not sure how to test transformers
Thanks!Leave a comment:
Does ON/OFF (blue wire) change when you press the power button?Leave a comment:
Pity - they look ok Is there anything to see on the back of the singed area. Did you check that diode - use diode setting on meter and post results.Leave a comment:
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
Assuming...7 Photos -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by mkdjDear all,
I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
I have checked resistance across each of the 4 MOSFETS. I have the following readings:
Both N-Channel Mosfets: nothing odd
P-Channel MOSFET number 1:
source - drain : 117 kOhm
source - gate: 96 Ohm
gate - drain: 117 kOhm
P-Channel MOSFET... -
by JDCONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge.... - Loading...
