need help finding alternate 24v solder point.
A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company. -
Re: need help finding alternate 24v solder point.
My replacement main board came today. After install the TV works PERFECTLY!
I'm thinking there may be issues with the main boards on these models. This makes 2 main boards which have gone out within the last 2 years.Comment
by ReplayGemI have an Acer E15 (E5-571) that is loosing all settings whenever unplugged. I got a replacement battery however the original battery broke off from the motherboard and the positive lead broke away completely. I tried scrapping the board and soldering the new battery to it however it still looses all settings when unplugged. Is there an alternate point on the board where I can solder the positive lead of the battery? I found schematics of the board on the forums however I have no clue how to read it.
Thanks. -
This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....09-12-2024, 02:00 PM
by corrizeHello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
See the test :
https://youtu.be/bNAzC-EvqHs?t=1767
With hot air from bellow the board, that's... -
by DynaxSCHi,
Usually on ASUS boards it worked...-
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... - Loading...
