Samsung LE40A656A1F Black to Red Screen Error
  • mrbishi
    • Aug 2012
    • 14
    Re: Samsung LE40A656A1F Black to Red Screen Error
    I'll check that out in the morning Tom, I am actually starting to wonder if its just down to it been turned off for so long, its gone on and off now twice but for a good few hours has stayed normal, Ill play if from here for now and see what happens, cheers for the good advice thus far however
    • mrbishi
      • Aug 2012
      • 14
      Yes its set to Default, inside that menu I did notice a EEPROM reset option, as you said corruption of that could be a possibility would a reset be advisable?
        Try it, but since it is going away occasionally it sounds like a loose connector or a T-con problem.
        • mrbishi
          • Aug 2012
          • 14
          OK mate I'll give it a shot but I think your probably correct with the latter explanation(s) Ill give the LVDS a pull and put it back in, if not I've already priced up both a LVDS & TCON replacement, Ill buy the LVDS first has its the cheapest, if that doesn't solve it then the TCON haha finally the mainboard, even if non of them work I've got the parts and can resell cheers for all your help Tom you've been a star
          • mrbishi
            • Aug 2012
            • 14
            Well I'm pleased to say after opening it back up and unplugging the cable which runs from the main board to the t-con and cleaning around the t-con (some area I'd previously not cleaned) the problem has been solved with no extra costs incurred
            Not sure if it was the dust all over the board of the t-con or the cable possibly been knocked when cleaning it first time round :? but won't lie I'm a happy chappy and its been almost problem free since.
            So what is the problem you may now ask hahaha.......
            Well I wired my spare desktop PC upto it but having wired up the soundcard to the selected ports on the back of the tv I'm not getting any sound, does anyone have any ideas to why this may NOT be happening lol, I really wanted to use it so I can skype my family round the world don't fancy having to buy external speaker system just for the PC sound, the PC soundcard works fine I've checked it so the fault definitely lays within the tv or its settings?
              Where have you connected audio in? This TV has PC audio in port, as well as DVI/HDMI audio in, you can select which one the PC uses I think from the menus.
              • mrbishi
                • Aug 2012
                • 14
                Mmmmm did not know that, well I attached the PC via the PC port and a normal PC monitor cable, I used a mini jack to RCA lead to wire the sound card to the two RCA ports marked PC Audio
                  Try the little jack like a headphones jack, I think that is PC audio input.
                  • jetpilot
                    • May 2013
                    • Sweden
                    #29
                    Hi Tom,
                    I have a samsung tv with model nr ps42b455b1wxxe and the picture has turn out red. I have talked to the serviceguys and they said that you could tune that in servicemenu that what they did last time i had this problem, but i dont have any guarantee left so thats why i need to figure out how to set this by my self. Can you please help me?
                    Regards
                    Daniel
                      You may be able to do so Daniel. If you start a new thread you will receive a lot more help.
                      • umidunnoy
                        • Aug 2013
                        • 5
                        • erie
                        #31
                        Hi I have a Samsung lnt4042hx/xaa with a red screen instead of black plus a red distortion.....this happen occasionally. I tried cleaning the ldvs where is plugs into the tcon and it seem to work but then went red again after 4 hrs or so...any advice would be awesome thanks
                        • Nerfinator
                          • Feb 2015
                          • 56
                          Originally posted by randtek
                          I just repaired a Samsung with a similar issue by cleaning the connectors at both ends of the LVDS cable. It may not help your issue, but it is worth a try.
                          THANK YOU!!!! I had one that was doing this and that's all it was!!!
                          • Nerfinator
                            • Feb 2015
                            • 56
                            Originally posted by tom66
                            Yep, info-menu-mute-power works on every Samsung from ancient CRT RPTV to 6 month old plasmas.
                            Just fyi, this does not work on US Samsung TVs. I know you and the original question poster is in the UK, but I just wanted to toss this out there so if someone else from the States come across it, they don't think there is something more wrong with their TV when it doesn't work for them, but thank you for posting about it!
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • HTR-Informatique
                              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                              by HTR-Informatique
                              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                              I also changed the screen because the PC fell and the screen was broken.
                              I changed the battery with a new and original battery.
                              I also had corrosion/oxidation on the...
                              02-09-2025, 06:51 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • VcemPzd
                              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                              by VcemPzd
                              Hello everyone !
                              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                              04-28-2025, 10:14 AM
                            • Chrissygizmo
                              by Chrissygizmo
                              02-10-2025, 12:33 AM
