bad power supply cap ?
  • OrderOfSolve
    • Aug 2012
    • 3
    I have a LG flatscreen tv model 20ls7d-ub. It's got 2 bad caps. one of the caps that's bad is a Samxon 680uf 25v 105°C8 V1A. What does the V1A mean?? What can I cross it out with? The other bad cap is the same value but GF(M)? Thanks in advance!
  • japlytic
    • Oct 2005
    • 2086
    Re: bad power supply cap ?
    Welcome, OrderOfSolve!
    Samxon GF series have been known to go bad after some use; so I recommend replacing all of the Samxon GF Series units with Chemi-Con KY Series.
    The V1A appears to be a date code.
    • c_hegge
      • Sep 2009
      • 5219
      Or Nichicon HE, or Rubycon YXG. All have the same specs as Chemi-con KY.
      • OrderOfSolve
        • Aug 2012
        • 3
        Just ordered several Chemi-con caps from Mouser.com. Thanks for your help! I'll get back with the results! Thanks again!
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          True.
          But japlytic has Chemicon OCD .
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • CMCM
            Russound CA4 Power Supply Repair
            by CMCM
            Hello Everybody,
            Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
            Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
            The outputs marked 12v and 20v are all measuring only 1v.
            The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
            The capacitors physically look clean (no bludgesor leaks) and...
            07-03-2025, 01:12 PM
